SOLD For Sale--F350 Superduty FX4
SSCCJL
2018 F 350 Super-Duty, SRW, 6.7 diesel 4X4 with 6 speed automatic transmission.
This truck was purpose built for heavy duty towing or off-road truck camper use.
With 19,700 miles of mostly highway use the truck looks and drives like a showroom new.
Ford FX4 off-road package. Steel road wheels ( 18”), with 35x12.50 Toyo Open Country RT off-road tires.
The truck has heavy duty F450 upgraded front springs and Fox 2.0 performance series shocks, on all four wheels. The factory Camper Package, rear springs with sway bar and goose-neck 5th wheel package, The truck can accommodate either a slide in truck camper or tow at full rated capacity. Torklift camper tie down brackets. Trailer brake controller. 4 Wheel anti -lock disc brake.
Manual shift transfer shifter on floor and manual locking hubs in front for reliability. Electronic 3.55 locking axel, with skid plates.
Two HD batteries with warming blankets, and two HD alternators. Battery isolator switch for second battery and block heater. Inverter provides 110 volts in the truck.
Heavy duty Anderson 12v connector on grill provides battery power to Warn 16,500lbs winch, and enables jump starting the truck with 12 volt power.
Heavy duty Buckstop steel bumper with attachment points for High Lift jack and other recovery equipment. Winch has 100 ft of synthetic rope and 100 Ft of wire rope as spare.
Truck bed has factory spray in bed liner and the under body was undercoated by Ziebart, when new.
Weathertech floor mats throughout.Preferred equipment package,Power equipment group, 50 state Emissions, telescoping power mirrors, Sirius XM radio, Air cord, rear view backup camera, Hill start system. truck bed hard tonneau cover, Removable heavy duty folding front hitch cargo basket,
Warranty-Ford 5 year -60,000 mile power train and additional Ford bumper to bumper warranty, Valid to 5-23-2023-48,000 miles.
This truck has only been serviced by FORD.
Located Newport Beach CA
Asking $58,500.00
SSCCJL
SSCCJL
Yes the same truck but now in California with a few additions. I have had to cancel my plans to build a truck camper and don't need the truck.
Ninelitetrip
All I see is the addition of some electronic device on the center console, change to the winch, and side steps.
It's a nice setup.
From the previous listing.
2018 f350xl diesel supercab 4x4
14500 miles.
Heavy duty buckstop steel winch bumper with 7/8 recovery shackles
Warn 16500 lb winch With forged 1/2 CM hook.
Bumper also has mounts for reciever hitch,high lift jack bar with baseplate and a 14000 lb land anchor recovery spade.
Toyo 35x12.50 ridge grapplers on heavy duty ford 18 inch steel wheels.
Fox 2.0 shocks with upgraded f450 front springs and camper package rear springs with sway bar.
Manual transfer case shift lever on floor and manual locking hubs.
Locking rear axle and front axle has a differential skid plate.
Dual heavy duty batteries with on board chargers and warming blankets And battery isolator switch for 2nd battery, winch also has heavy duty battery isolator switch.
Engine has a block heater.
Heavy duty Anderson 12v connector on grill provides battery power to winch and enables jump starting the truck or other vehicles or provides 12v power.
Has 110v male plug on grill to power battery chargers ,battery warmers and engine block heater.
Options on truck include dual extra heavy duty alternators, gooseneck and fifth wheel kit, skid plates, 110v outlet in dash, trailer brake controller, spray in bedliner with lockable bed tie downs and in bed lights. Upfitter switches, remote starter, tailgate step, roof lights and all Weathertech floor mats.
truck was professionally undercoated by Ziebart for corrosion protection when it was new but truck never seen any winter driving or salt so frame and underbody Are in almost new condition.
Truck was only serviced by ford dealership and is still under warranty of 3yrs 36000 miles bumper to bumper and 5yrs 60000 miles power train
all of the heavy duty recovery gear and front cargo basket are going to be included with sale of truck.
The recovery gear mounts to front of truck with high lift ratchet mechanism and pull pal bar behind rear seat.
everthing has padlocks on bumper so it doesn’t “ fall off “ when truck is unattended.
*Military size pull pal 14000
*shovel
*highlift jack extreme
*high lift jack heavy duty baseplate
*two maxx trax
* heavy duty folding hitch cargo basket with custom L-track rails and tie downs.
( can Carry a very large Heavy cooler Or wood box)
stainless steel torklift mounts
Mcoleman
