sold - FS: National Luna Portable Power Pack
03bart
SOLD - National Luna Portable Power Pack. Great condition.
National Luna fused cables and instruction manual included. Negative cable 94" long, positive cable 120" long. You will need an Anderson Power Pole SB50 connector (https://powerwerx.com/anderson-sb-connectors-sb50-50amp) to connect the cable to the Portable Power Pack.
$300 shipped. Or local pickup and you get the Optima D31T Yellow Top with it.
Colorado Springs, CO
03bart
Pending funds
On hold pending funds. All PMs replied too.
It does have cables, but you will need to supply an Anderson Power Pole connector for the Nat Luna box end of the cable (the original cable connector on the cable cracked). Also, the cables are cut down for my application, so you may need to supply new cables if the distance from your battery to the box is longer than mine was.
11r514x4
