1977 Suzuki GS750. Clean title. Bought as a project and completed the following: took it apart to the frame and engine, new (used) instrument bezel, new handle bars, 06-07 GSXR front master cylinder and resevoir, front stainless braided brake line, rebuilt rear master and resevoir, rear stainless braided brake line, new valve shims within spec, new front sprocket, new rear sprocket, new chain, new gaskets all around (except for head and cylinder), new air filter, new cylinder head intake boots, cleaned and completely rebuilt carbs, new clutch cable, new brake pads, rebuilt front and rear calipers, new plug caps, new clutch springs, new allen head engine hardware kit, cleaned up and fixed wiring. All electronics work. New tires. New grips. Have tons of spares and stock parts. Also have case savers that are not installed. Painted valve cover caps, head light bezel, headers and slip ons, and rear fender flat black (sand blasted, primed and painted, headers and slip ons were painted with high temp exhaust paint). Oil and filter are new. Battery is new, and kick start works also. New spark plugs. Needs fork seals.
Can ride it as it sits.
Comes With: Case savers, 2 more oil filters, all the stock stuff I removed (rear fender, old brake lines, blinkers, tail light, etc, etc.)
I can take as many pictures of whatever you want on this bike, and will answer all questions.
$1800.00 obo
$1800.00 obo
