Hoytshooter724
I have for sale a brand new in box EccoTemp L10 tankless hot water heater. This model is made to be mounted outside and comes with a rain cover for the upper vent. The ignition runs from 2 D-cell batteries. This does not have a pump built in. Unit is too big for my project. This is the companies plug.
The Eccotemp L10 Tankless Water Heater gives you endless hot water at your cabin, summer cottage, lake home, potting shed, RV, camper, farm or wherever else you need hot water. The Eccotemp L10 Portable Tankless Water Heater delivers up to 2.6 Gallons Per Minute of hot water ranging from 80-145 degrees Fahrenheit: plenty for 1-2 hot water applications running at the same time. The 2 "D" cell battery ignition starts the flame only when water is running, so there's no chance of overheating. It is perfect for off grid or areas where you have limited electricity. The L10 comes with standard 1/2" NPT fittings. The ideal operating range is 20-80 PSI. The system also works great on modified water systems with items such as a 12-volt pump.
SOLD!!!!!
SOLD!!!!!
