**SOLD** Horizon Adventure Trailer
DaktariEd
2005, 2006 Tech Course Champion: Expedition Trophy
"Horizon" Adventure Trailer
This Adventure Trailers (AT) "Horizon" was purchased new in December 2005. It has:
• Heavy duty 14 gauge steel laser cut chassis, powder coated corrosion protection
• Side protection bars
• 2" Receiver type tongue and 2" rear accessory/recovery receiver for accessories
• Lock and Roll multi-axis coupler for articulated travel on & off pavement
• Stainless steel hinges and latches throughout
• Gas strut assisted cargo lid
• Interior cargo tie down points
• Cargo floor rubber mat
• LED lighting and reflectors
• AT Roof Rack and a Maggiolina Airland rooftop tent
• Textured black chassis and suspension, high reflective white body components
• 12x33" wheels and tires.
• Electric break-away brakes.
The AT Kitchen fits conveniently into the passenger side box, and utilizes a high output 2 burner stove on a slide mechanism. A removable cutting board is built into the door, and the space within the box provides for storage of cutlery, kitchenware, and other essentials. A 2.5 gal propane tank is mounted just behind the tongue on the right.
A 6′ x 6′ Fiamma awning (self-contained within an aluminum clamshell tube) mounted on the top of the kitchen box with height adjustable supports.
A fridge tray (sized for an Engel/ARB 45) inside the main cargo box, mounted on a full slide out tray, allowing the fridge to be pulled out over the tail gate for easy access. A 12-volt power port supplies power inside the cargo box.
The mid-section of the Horizon trailer tongue has a built in skid plate and is used to house the 19 gallon water tank made from food grade plastic (BPA free).
The space in front of the water tank is fitted with two 5-gallon/20 liter fuel or water cans and holders.
A large nose box at the front of the tongue holds a deep cycle battery, inverter, 12-volt outlet, with plenty of extra storage space.
$7500
Contact by PM or e-mail please
Additional links and information:
Adventure Trailers: http://adventuretrailers.com/trailers/horizon/
DaktariEd
The trailer is in good condition.
As you might expect from the many miles it's been on trails, it does have the usual small rock chips in the front facing paint (see photo).
I was going to apply some diamond plate over these exposed surfaces....never got around to it. That would be a good project for the new owner. :ylsmoke:
The interior is fine; no rust anywhere (we don't get much rust here in the desert!).
I'll attach a couple of photos...the interior is still a little dusty; I haven't cleaned it out recently!
The brown stuff along the edge is sawdust. :sombrero:
There's a voltage inverter in the nose box for 120 volt in camp.
The battery charges through the towing vehicle or via a solar panel if you have one...
The Maggiolina Airland mattress is now "memory foam, 3" thick, 54x72".
ilciclista
