SOLD. Low Mileage Stewart & Stevenson 4x4 LMTV Overland Vehicle - Only 31k Miles. $140K.
vagabondette
This low mileage Stewart & Stevenson rig is tough as nails and immaculately clean. It has a beautiful camper box that was professionally renovated in 2018 by Plan B Supply (Ogden, Utah), with the idea in mind that adventuring can also be comfortable. With 1000 watts of solar panels, it's made for spending time off grid. We recently put on five all new Michelin tires (and "new-new", not "new-used"). It was built with safety/security in mind, with security film on the windows (except front), heavy duty security hasps on all exterior compartments, and a lockable pass-through between cab and cabin. Mechanically, it has no known issues and has been very recently serviced. The truck drives quite smoothly considering its size, and the turning radius is surprisingly good (no big wide turns like a bus). It has cameras on both sides and the rear so it's easy to stay safe. It is located in Kansas City, and we'd be happy to set up an in-person viewing & test drive for anyone interested.
Pics below and please reach out with any questions.
Overview:
  • 31,000 miles
  • Total length: 25 ft 8 in (18 ft 8 in body)
  • Sleeps 4
  • Locking cab-to-cabin access
  • Separate dry bath
  • 8 solar panels (1000 watts)
  • Motorized lowering queen-sized bed
  • U-shaped dining area seats 6, convertible to queen bed
  • Double ultra-leather swivel recliners
  • Camper box gutted and completely renovated in 2018
  • Vehicle located in Kansas City.
Chassis: 1997 chassis. Ultra off-road capable, it has a 275hp Caterpillar 7.2L, 6 cyl turbo diesel engine (does not require low-sulfur fuel), 817 ft-lb torque, 7-speed automatic Allison transmission with rock-crawling granny gear, central tire inflation system (automatic highway, cross-country and sand mode), 17,500 lb recovery winch, extra-large fuel capacity, full time all-wheel drive with 4x4 mode, and 5 new 48” deep-tread, run-flat Michelin XML tires.
Camper Box Construction: Full 1/8” thick aluminum-welded framing and four-season insulation with heated basement enable travel in extreme temperatures.
Living Area: Luxury living features include kitchen with quartz countertops, two-burner induction stove, marine-grade Vitrifrigo fridge, zero-radius stainless steel sink, soft-close drawers, dry bath, endless hot water, outdoor shower, ultra-leather swivel recliners, white oak hardwood flooring, and a U-shaped dinette with a solid walnut table. Interior sleeping space is maximized with a motorized queen-sized bed that descends from the ceiling over the dinette area that converts into a second queen-sized sleeping area. The vehicle sleeps up to four people.
Storage: External storage includes a safari rack with three hard-mounted weatherproof containers, five external compartments with high-security hasps, and a 20 CF garage. Storage has LED lighting and a combination of 120V and 12V outlets. Internal storage consists of built-in cabinetry throughout the main living area, mounted netting around upper bed, double cabinets in wash room, single shelving in shower room, four wall-mounted single bookshelves behind the recliners, and dinette bench storage.
Usage: This vehicle has just 31,000 miles with approximately 100 days of travel time. It is registered as an RV; no CDL required.
SPECS:
LMTV Chassis:
  • Caterpillar 3126 Engine - Heavy duty diesel, 6-cylinder, electronic controlled, fuel-injected, 7.2L
  • Power steering, automatic 7-speed Allison transmission
  • 17,500 lb recovery winch
  • Electronic Central tire inflation system
  • Anti-lock Braking System
  • Full-time all-wheel drive (w/ 4x4 mode)
  • Torque: 817 ft-lbs
  • Speed up to 62 MPH
  • 55g fuel tank with additional 30g transfer tank
  • Safari lights
  • AmericaLoc vehicle tracker
  • New 48” deep-tread Michelin R395/75/R20 XML tires
Cab:
  • Air ride cab
  • Insulation & sound dampening
  • Lockable cab-to-cabin access
  • 360-degree camera coverage
  • AM/FM Stereo, XM-Ready
  • Hard-mounted security box
  • Middle jump seat with car seat anchors
  • Cab sound dampening
  • 12 volt lighter/USB port
Camper Box:
  • Length: 18 ft 8 in
  • Exterior width: 8 ft 4 in
  • Interior width: 8 ft
  • Interior height: 6 ft 10 in
  • Ultra-durable rhino lining
  • Fiamma F45S electric 9ft long awning w/ 8’2” extension
  • Cab-to-cabin access (lockable with insulating plug)
  • Energy efficient dimmable LED lights throughout body
  • 3M automotive security window film
  • Screened windows and door
  • Spare tire mount, rear w/electric winch
  • Exterior storage
  • Safari rack with hard-mounted storage
  • Safari lights
  • Heavy duty security hasps on all external compartments
  • External storage garage, 20 CF
Kitchen:
  • Induction cooktop, 2-burner, MiniDuo
  • Undermount zero radius stainless steel sink w/built-in soap dispenser
  • Marine-grade stainless steel Vitrofrigo Refrigerator, 2-drawer style, 5.1 CF capacity
  • External removable Dometic 26L freezer/refrigerator
  • Caeserstone quartz countertop & backsplash (Color: Organic White)
  • Frameless white melamine cabinetry
  • Soft-close drawers
  • Sliding garbage can tray
  • Extra long countertop, 7 ft 8 in
Dining Area:
  • U-shaped dining w/ marine-grade pedestal (seats 6); converts into auxiliary sleeping area
  • Solid walnut tabletop, 1 in thick
  • Ultra durable microfiber upholstery (washable/changeable slipcover)
  • Dual USB`/12V ports on both sides of dinette
Living Area:
  • 2 swivel recliners in ultra-leather with walnut pull-out side tables
  • Four (22 in long, 4 3/4 in deep) wooden bookshelves installed behind recliners
  • Slow-Rise blackout shades throughout cabin
  • Privacy curtain separates bathroom area from cabin
Bedroom:
  • Descending queen-size bed above dinette
  • Queen-size memory foam mattress
  • Headboard w/built-in storage and charging station (120v outlets & 2 USB ports)
  • Privacy shades
  • Dinette couch converts to queen-sized bed
Shower Room:
  • Extra large shower: 34”x28”x78”
  • Mounted metal corner toiletry rack
  • Window with storage shelf
Wash Room:
  • Caeserstone quartz countertop (color: Organic White)
  • Stainless steel sink
  • 3/4 length lighted wall mirror (24” x 40”
  • Cabinet over toilet
  • Cabinet below sink
  • 120V GFCI outlet
Finishes:
  • Caeserstone quartz kitchen countertop (color: Organic White)
  • Caeserstone quartz kitchen backsplash (color: Organic White)
  • Caeserstone quartz bathroom countertop (color: Organic White)
  • White melamine frameless cabinetry
  • White oak hardwood flooring (engineered)
  • Recessed lighting throughout
  • Marine-grade cabinet and door latches
  • Matte black and stainless steel fixtures
  • Ultra-durable microsuede slipcovers on dinette
Electrical:
  • Controls for systems management and monitoring
  • 12v w/120v systems with shore power inlet and interior outlets
  • 12v voltage inverter, 2000W
  • 120v shore power connection
  • Marine grade shore power cable
  • 5 solar panels, 200 w ea
  • Circuit breaker and fuse panel
  • 4 AGM deep cycle batteries providing 600 amp hrs
  • Battery disconnect switch (separate kill switches for box and cab)
  • Energy efficient LED lighting throughout
  • WeBoost cell phone amplifier
Climate Control:
  • Dometic rooftop air-conditioner (camper box)
  • Diesel heat
Plumbing:
  • Gray water tank: 40 gal
  • Black water tank: 37.5 gal
  • Fresh water tank: 120 gal
  • Dometic foot-lever flush toilet
  • Outside shower
  • Attachable black tank macerator (black water grinder)
  • Concealed PVC tube for black water hose.
  • Clearsource premium double mechanical water filter system
  • HQUA UV purifier/sterilizer
  • Endless hot water
Misc:
  • Built-in steel Viking safe with key/code/fingerprint access; internal dimensions: H 4.5” x W 10.5" x L 14.5”
  • (4) MaxTrax in yellow
  • Car seat anchors for cab middle jump seat
  • (3) Diesel 2-gallon Rotopax
  • 1) Gas 2-gallon Rotopax
  • (3) Lockable, hard-mounted storage boxes on safari rack
  • Trasharoo for external garbage storage
  • LED lighting and 12V/120V outlets in external storage compartments
HuntressOffroad
Hi there. I’m interested, but can’t make it out to KC to see it until after I the new year. I do have some questions though: do you know how much the GVWR is at this point? How much weight can the vehicle still hold until it’s maxed out (how much stuff and gear can I load it with)?
vagabondette
Hello, It's at 20,000 lbs now and can carry 2,500 more lbs. We are in KC through January 25, and then are going to be out of the country for a while. Do you want to set up a time to see it before then?
XPlorist
Are these single or dual pane windows? Do you know what kind of insulation was used. Diesel hydronic water/air heater?
Thanks
vagabondette
Thanks
They are single pane windows. It has foam sheet insulation. There is a diesel furnace that provides continuous hot water. The furnace provides hydronic heating to heat exchangers throughout the box that have fans to blow the heat into the living space and to keep the basement warm. The system also has an electric heater that can be used instead of the furnace and is about 1500W. We've stayed in the truck in freezing weather and it was very comfortable, i.e., no drafts or cold spots.
Chonker LMTV
