boisefj
For Sale: Overlanding Trailer w/ Eezi Awn Globe Tracker Tent,
Contact Ty, Call or text 208-407-1265 or respond to listing.
Located in Boise, Idaho, Asking $8,700, or best offer, for our 2010 Overlanding Trailer with:
*Eezi Awn Globe Tracker Tent, 4 Season Tent which has a Queen size Bed, 470 sq ft Annex living space that can accommodate a combination of 2 full size cots, or 3 tables and 2 chairs.
Tent Condition - Used but in good condition. Frame is in excellent condition, Fabric has no rips or holes. A couple of attachment points need resewing. Zippers are 100% functional and in good shape. Bug mesh is in excellent condition with no holes or rips. Mattress is in good condition, no holes and still provides basic padding.
Rainfly is in good condition and provides protection in inclement weather.
*2 Tent Covers, 1 used in good condition (used when storing tent) and 1 new cover, used on trips, has been on 1 trip.
Tent cover will fit to accommodate supplemental mattress and bedding, access ladder to queen size bed area is stored there also.
3-1/4" Thick Hi-Density Foam Mattress Covered in African-Printed Fabric
Aluminum ladder for access to bed area.
Ground cover, not attached to the wall set, made from very thick PVC mesh that lays on the ground over the attached floor piece, providing closure between the wall and the floor.
Tent Accessories bag w/ Stakes, Rainfly supports, instructions,
*Trailer is a 2010 made in Kamiah Idaho
Trailer Condition - Used but well maintained. Cargo interior is in good condition, has a pad on floor for 3/4's of the length to help protect items.
Exterior dimensions of Trailer - 12’ 7” total length x 5’ 11” Wide Fender edge to Fender edge x 5’ 8” Tall from ground to top of folded Tent ( Depending on what you store on the bed, the height could be a few inches taller. )
Interior dimensions of storage space - 70 .5” Long x 39.5” Wide x 24.5” Tall - These measurements are at the narrowest parts of the interior.
Leaf spring suspension
6 Lug pattern wheels, Tires in good condition with decent tread amount.
Gas piston assisted hinged sealed lid with lockable lid.
3 Tent 1”x1” tubular steel supports bolted to top of lid
Rear drop down tailgate behind spare tire Swing out.
Heavy Duty load bearing fenders
LED Tail Lights
Heavy duty dual tongue wheel for moving on rough terrain.
Trailer comes with:
*2 Water Tanks a K-9 brand 10 gal and Ironman 4x4 brand 13 gallon conformal with new hoses.
*Full size spare Tire on a Swing out mount
*Rear receiver hitch for bike rack.
*Third Leg support device for stability when Tent is deployed.
*Freshly packed Wheel Bearings
*Fully articulated hitch & Receiver,
*1.5 gal Propane Tank and Mount
*Pair of Wheel Chocks and Tongue Wheel cradle.
•Tire lug wrench
Globe Tracker Tent Specifications
LED Tail Lights
Trailer comes with:
•Tire lug wrench
Dimensions | Closed : 83" L x 59" W x 7" H | 2100mm L x 1500mm W x 1850mm H Open (Includes Ground-Level Room) : 83" L x 152" W x 118" H | 2100mm L x 3800mm W x 1500mm H Ground-Level Room : 83" L x 93" W | 2400mm L x 1500mm W |
Weight (Including Ladder) | 165 lbs | 75 kg |
Mattress | Queen |
