SOLD - Selling 2019 Patriot Camper X1-N Limited Edition Desert Ops #10/20 with BUNDATOP Electric Roof Top Tent Standard Size
nick@nite
2019 Patriot Camper X1-N Limited Edition Desert Ops #10/20 $35,000
Color: Sandy Taupe with Retro Stripes
* Redarc Manager30 With Switch Panel
* Patriot X-Rack Mounting System
* Rear Drawers incl. 6 dividers
* Twin Burner Gas Stove
* Plumbed On-demand Gas Hot Water Service
* 270o Awning With Gas Assisted Lift
* Awning Infill Panels
* 40 gal Water Tank Capacity
* 2 (150AH)x Gel Batteries
* X-Cruise AIR 1.60T Dual Shock Suspension
* Standard 6/139.7 Stud Pattern – 12” Electric Drum Brakes
* PCOR 16” Wheels – ET0 & 35’ Mud Terrain Tires (x3)
* Spare Full Size Wheel/Tire and Rear Swing-away
* 1000Watt Inverter with Charging Shelf
Options include:
* BBQ Swing-away with Weber Q1000
* Second Propane Holder and two propane tanks
* ARB 63Qt Fridge w/Mounting Kit
* 2 New Maxtrax mounted
* 2 Gas Bottles
2019 BUNDATOP Electric Roof Top Tent Standard
* Weight appx: 175 lbs
* 82 inch x 53 inch x 12 inch in when closed
* 82 inch x 53 inch x 41 inch exterior height (36 inch interior height) when open.
* Full electric operation
* Shade awning around all four sides of the tent
* Tent fully erect, with awnings, in 30 seconds at the press of a button.
* Tent fully closed, all sides & awnings folded away in 30 seconds at the press of a button
* Window covers zip open/closed from the inside
* Insulated roof inside
* All aluminum construction
* Stainless steel supports: The tent has an existing aluminum frame built into the bottom.
Includes:
* Solar wiring (see info below)
* 4 inch high density foam mattress
* 12V outlet inside
* LED light inside
* All aluminum construction ladder (double sided)
potfish
Would you consider selling without the Bundutop tent, if you can find a separate buyer for that?
Other than the tent and the propane cylinder stuff you mentioned is there anything different between your unit and the one in Patriot Campers' YouTube video for the Desert Ops edition?
Smithmds77
