SOLD SOLD SOLD 2021 Schutt Xventure XV-3 Trailer
J squared
SOLD SOLD SOLD
2021 SCHUTT XVENTURE XV-3 TRAILER
Built with military-grade hardware, Huck bolt construction, and an aluminum cargo bed.
Built for off-road performance with an independent torsion axle, electric drum brakes with emergency breakaway system and multi-axis Max Coupler hitch.
Area lighting packages provide for up to 360 degree of lighting coverage to include under body, cargo and rack lighting through-out the trailer (part of deluxe package).
TruXedo’s Titanium hard roll-up truck bed cover offers full bed access while allowing the added security of a hard-paneled tonneau. Slim, low-profile design allows little wind drag, while adding strength and durability (part of deluxe package).
Length — 131 inches Curb Weight — 850
Width — 80 inches Payload Capacity — 1500 lbs
Height — 50 inches top of tonneau cover; 67 inches top of rack
Build Date — 06/2021 GVWR — 2300 lbs
Cargo Bed Interior — 49” x 65” x 19”
Finish — semi-gloss white standard
Axle Clearance — 15 inches Tires — 235/80R16
Suspension — independent rubber torsion
Lighting — all LED Wheels — 6-5.5” bolt pattern black
Construction — 6061-T6 aircraft grade aluminum
STANDARD EQUIPMENT
XVENTURE Trailer – All aluminum construction, includes the following plus standard trailer amenities such as front wheeled jack, rear adjustable vertical stabilizers, safety chains, etc.
  • Fully D.O.T. compliant in all 50 states
  • 3 Piece Step-Style Fenders - Designed to support full sized adults to access rack cargo
  • Line-X coating - cargo bed interior, steps, fenders, tailgate, and front tool box
  • Power Distribution Center - Completely wired with fused switchable supply ports. This allows you to integrate electronic accessories like additional lights, compressors, pumps, charging units etc., to a fused circuit that is remotely switchable from the control center switch block.
  • Wiring harness runs through chassis tubes for optimal protection
  • Exterior mounted weather proof marine grade 110V shoreline-in receptacle
  • AGM 50 AH deep cycle battery and charger
  • Solar charge controller with SAE plug input
  • Cargo bed mounted 12V receptacles on either side of bed at rear
  • Lighted license plate mount on tailgate
  • 2: 31" Low Rolling Resistance (LRR) LT tires on 16” steel wheels (6 on 5.5” bolt pattern)
  • Rear 2" accessory receiver (100 lbs capacity)
  • Swing-away tailgate and integrated stainless steel galley table
  • Fixed height rack
  • Large front tool box with three compartments and locking lid
  • Dual independent manual parking brakes
  • 10 year warranty on chassis (yes, it's transferable to new owner)
DELUXE PACKAGE
Complete water system with 22 gallon tank, skid plate and plumbing
  • Water heater, propane, shower head, and 8’ hose
  • Complete LP system kit includes 5 lbs tank and tank mount
  • Hard tonneau cover
  • Area lighting basic and expansion - 4 rock lights, 2 bed lights, 6 rack lights
  • Rhino-Rack Pioneer tray
No known problems.
Approximate miles on trailer — 6,000 (highways and campgrounds; no offroad)
Always garage kept when not camping. Cleaned immediately after each trip.
Water tank/pump/heater never used.
All manuals we have are included.
Title in hand.
Hobietim
Hello, our XV-3 deluxe was destroyed by an errant driver and we are fighting insurance over value. ours was a '22 almost identical can you kindly share the sale price?
roamingraven
