Sold thanks: 1995 Mercedes G320 LWB with rear jump seats, 3 diff locks, 119k miles, well maintained
Mike Serpe
Very low entry price on this nice straight G which was in Osaka most all its life (no winters, no salt)
Some cosmetic updates, lights, mirrors, fog lamps G550, wheels G550 etc. Steering wheel from later G320/500 with wood accent.
Has custom seat covers which are really nice. Has rear folding jump seats in the cargo area.
Very solid maitnenance records including
  • 2000 air conditioner condenser
  • 2001 air conditioner compressor
  • 2002 fuel pump, fuel filter, radiator upper hose lower hose, water pump
  • 2003 air conditioner condenser
  • 2009 battery, blinker relay
  • 2010 engine gaskets, tappet gaskets, V-belt pulleys, idler pulleys, shift linkages
  • 2012 battery, front power window, V belt pulley, power steering hose, fuel filter, differential oil
  • 2013 ignition key & lock-cylinder
  • 2014 engine main harness, mass airflow sensor; A/T overhaul / filter / etc.
  • 2015 accelerator cable, axle shaft seal, fuel gauge, brake hose, drive shaft boot
  • 2017 over-voltage relay, turn signal relay, radiator upper hose lower hose, heater hose, fuel filter, chassis grease, differential oil
  • 2019 heater blower motor
  • 2021 chassis grease, differential oil, battery
  • 2022 air conditioner condenser
  • 2023 power window switch
  • 2023 Diff lock service.... one of six dash signal light not working but lockers work as they should
Car was originally ordered by AMG Japan and sold to one of their customers in Osaka.
Car needs to have new tires. We decide to have buyer choose what they want and priced accordingly low to factor that in. We can get tires at wholesale and mounted if buyer chooses.
Car comes with a clear WA state title and BOS
Mike Serpe
bump
price lowered to 27500 including a new set of 4 tires of your choice or swap out for set of atik 16s with used snow tires on them
email Mike Serpe at mserpe@yahoo.com
founder, clubgwagen.com 1998
gwagenusa.com
Mike Serpe
sold thank you E Portal! I will stay in the Pac NW area.
Have some more avail: 2001 G500 Europa and 1996 G320 Short Wheelbase and 1998 G320 V6 LWB
cwhit5
