( SOLD)Trailrax With Pak Rax 4 Door Bronco New Price: 800
CLoverland
Trailrax Modular Roof Rack For the Ford Bronco 4 - Door. I have owned the rack for 2 years and never had any issues. You will notice some of the powder coating being worn over time but no issues with structural integrity of the rack.
Price: 1,200
Includes:
Modular Rood Rack
Pack Rax
Maxtrax panel
Rotopax Panel
Key Features: Fits: Ford Bronco and Bronco Raptor (6th Gen, 4-Door, 2021+) Overall height added to your Bronco- 3.845" from the center of the hardtop or 3.345" from the highest point of the hardtop (outer edges). Pak Rax load rating: 70 lbs per side respectively Static load rating of the rack: 850 lbs evenly distributed across the rack Dynamic load rating of the rack: 300 lbs evenly distributed across the rack Easy bolt-on rack install Wind deflector to minimize wind noise Cutouts for high-performance off-road lights All aluminum construction to avoid rust and corrosion Patented Pak Rax option to increase storage capabilities Offers the ability to remove the front and middle MIC hardtop panels while the rack is installed TrailRax was the first to build a roof rack for the Ford Bronco 6th Gen— and it’s still the best one on the market. The long-awaited TrailRax Ford Bronco 4-Door Roof Rack is designed to work seamlessly with the TrailRax Pak Rax, giving you endless gear-mounting options for overlanding and off-road adventures. Built from 5052 3/16" aluminum, the one-piece side panels offer extreme rigidity, durability, and load capacity, with a 90-degree bent channel providing 360° mounting flexibility for additional accessories. Our precision anodized black aluminum extrusions (TSLOTS) are made in Utah, cut to length, and stress-tested for maximum weight capacity and minimal deflection.
2eleven
