Hi all,
I purchased this amazing rig in 2008 from Canada and imported it to the US. It's legally registered and titled as a diesel in WA state. It was a professional swap done by Sheldon Walsh(G&S Cruiserparts) and it was his personal vehicle for a couple of years. I've put only 12k( 267k when purchased. 278,106 as of today) on it since I bought it, so I think it's time I pass it on to someone who can utilize it to it's full potential.
Sadly I am not an expert mechanic, but I will try to answer any questions best I can. Work done to it since I've had it: new radiator, fuel lines, fuel filter, air filter, valve cover gasket, rotors and pads(1k ago), new batteries(12mo ago). The body is still in great shape, I've added a scape on the front left fender, and the clear coat is pealing on the rt fender, no rust, garaged 90% of the time I've had it. It was worked on by a local cruiser expert, Torfab, and he gives it the thumbs up "We looked at this cruiser about a year ago, and it's in greae. For those in the know, this is a conversion done by Sheldon at G&S Cruisers in BC. His attention to detail is top notch, and this conversion is very well done."
Here is the original description that was posted in '08 and like I said little has changed:
93 FZJ80, Dark Green ,No lockers. Clean Carfax, no wrecks on record. Seattle/Tacoma truck so no rust whatsoever, and not baked out like Southern US 80s either.
267k Miles on the ODO FWIW the only drivetrain wear items that is still original is the diffs.
Clean grey cloth interior, Not kid worn, put in new Toyota floor mats when I got it 2 years ago.
Paint is in decent shape overall, usuall wear and tear from 15 years of use.
2 small dents on driver fender where my roof rack tipped against it.
Some clear coat starting to flake on one of the flares
leather steering wheel(Genuine Toyota)
3rd row seats
AC R134 and blows cold.
JDM 80 series aluminum running boards.
JDM passenger side grab handle
Center Diff lock button installed, Pin 7 mod done
ARB Bull Bar(winch type)
PIAA Headlamps
Safari Snorkel
OME Medium lift (2.5") 850/860 coils, OME Nitrocharger shocks, OME steering stabalizer
New 285 75 16 BFG All terrain KOs, load range E (maybe 5k miles on em.)
Wholesale Automatics "Extreme Valve body" in the A442F tranny. Quicker tighter shifts, less slipage ($1200 not including instal cost)
Walbro 6065 Fuel lift pump. Low PSI fuel pusher eliminates injection pump starvation and cavitaton
Isspro colored face Pyro (pre Turbo) and Isspro Boost gauge
Factory Dual battery trays w/ 2 Interstates (works with 1 battery if required)
Battery cables built with new#2 welding cable and marine brass terminal clamps.
Factory hand throttle assy
All correct HDJ80 decals on Rear quarter, emblem on grille, diesel decal on gas door.CD player, single DIN with factory pocket
Alpine 6.5" in front doors
Alpine 4" in rear doors
Class 5 hitch
1HD-T.. Engine had 140k km when it went in, has about 180k km on it now.
Engine was fully serviced, Valves reshimed to spec, compression all in 510-515 psi range, Nice and even with good oil pressure.
Turbo was rebuilt by ADP
Exhaust manifold and turbo dump ceramic coated
JDM ECT type A442F with HF2A transfer case, correct for the 93 model,
New from Japan 1HD-T ECT computer ($600)
New LHD HDJ80 Engine harness
BEB bearings replaced with ACL Copper/Lead type
Injectors serviced by Fred Holmes Fuel injection
New OEM Water pump, timing belt, Rear main seal
New 12v starter
New OEM fan clutch and fan assy
New OEM belts and Rad hoses
New rubber engine mounts
New OEM AC hoses
TONS of other new parts went into the swap, I won't list em all, total misc put into the swap NOT including the engine/tranny/case was $7500
Amsoil in everything but the crankcase Delo 400 15-40 every 3k miles
Washer reservoir relocated using proper JDM HDJ81 extra capacity reservoir on left fender.
As far as fuel economy goes it depends how you drive it. Pure Hwy @ 60mph on my last road trip, loaded with trailer, gear roof top tent etc I was getting around 400miles on 20gal.
My best was in stock trim. 507 miles on 21gal. The lift, bulbar , tires etc have all cost fuel ecomomy but the way I look at if is that I am still a good 30% ahead of any gas powered 80 in the same trim.
Asking $23,500. I'll post the pics I have now, and if anyone is interested in more pics or video, I'll try to accommodate through email or Skype.
NEW PRICE $22K!!!!:yikes:
3rd row seats
PIAA Headlamps
Safari Snorkel
Class 5 hitch
New 12v starter
New OEM AC hoses
