SOLD -- XP Camper/Nimbl on 2015 F350 XLT
ThatNewGuy
SOLD
uploaded a ton of pictures of both the truck and the camper to the google drive here: https://drive.google.com/drive/folders/16jj4PpkQx8aG19CvwMG4YQfYI497_uqT?usp=share_link
let me know if I can answer any questions.
Hi All,
I have purchased the truck+camper in this thread almost exactly a year ago. I have traveled in it for about a month across the US and then left the truck in Florida, near Tampa and went abroad for what ended up being an extended trip. It now seems like I will be based abroad for the next few years, so I've decided to sell the truck. I'm asking $100,000. The camper is located near Tampa Florida. I'm copying the description from the original thread below, as it still applies. I will also include a few items that I have purchased for using with the truck, such as propane stove to use outside, and Starlink Mini kit.
I will be in Florida for about 10 days in mid October, it would be the best if we can do the deal then, so definitely get in touch first so that we can tee things up. Any questions, just ask. You can see some of the pictures in the original thread, and I'm going to add more pictures I took during the trip here. Current mileage is 69,517 mi. During my trip I got just a notch over 14 mpg.
------- Description from the original thread below:
Body Construction
· Monocoque foam core reinforced with carbon fiber
· White gel coat
· Composite doors with all matching key locks
· Interior color-white
Interior Finishes
· Mahogany wood trim
· Vinyl marine teak and ebony floor with real teak trim Cabinet hardware (push button, positive locking hardware) Easy to clean marine grade headliner with storage pockets
Kitchen
· Countertop-fiberglass with water catch in black Faucet-SS, single handle with ceramic valve Hands-free electric operated water delivery system Stainless steel flush mounted sink
· 2-way fan over galley
· Overhead cabinet with LED under-mount lights
· All stainless steel hardware
· Large storage compartment under the sink
· Drawer over fridge on ball bearings with push lock
· 4.3 cu.ft. (1301) 12V compressor marine fridge with freezer
· Diesel cooktop x100 by Webasto
· Towel holder by the entry door and under the sink
Main Cabin
· High-grade foam for seats with fabric (from XP Selector)
· Table with drop-down sides - converts to bed
· Marine hardware for all hinges and latches
· 3 heat outlets in the main cabin
· 1 heat outlet in the storage area
· 2 LED lights
Bathroom
· Cassette toilet C402 – we just replaced the cassette in 2024
· Shower faucet-SS, single handle with ceramic valve
· Fan to vent bathroom and cabin
· Shower curtain
· LED light
· Toilet paper holder (waterproof)
· Retractable clothing line
· Teak grate
Bedroom
· Under bed storage
· Gooseneck xenon reading light in the bed area
· High-grade foam and Sunbrella fabric for mattress
· Front storage area behind tent in front nose of camper European spring mattress system from Froli
· Storage pockets above the bed
Windows
· All windows with built-in shades and mosquito netting
· 1 rear large dual pane window
· 1 side large dual pane window
· 2 side small dual pane window (kitchen and door)
· Tent with mosquito netting and removable privacy curtains 2 reversible fans in ceiling
· Large skylight with mosquito netting and sunshade
Water System
· 75 gallon heated fresh water tank with gravity fill
· 27 gallon grey water tank
· Shurflo pump
· Diesel water heater (Dual Top)
· Water gauge to monitor tanks
· All marine grade hoses with SS "v" hose clamps
· NEW – 3 filter water filtration system installed by NIMBL
Power Supply
· 2 solar panels @ 155W ea (7.1amp/hr) w/30 amp controller 2 batteries@ 300 AH AGM 6V ea (300 amp 12V) (see extra option section for more info on solar panels etc..)
· Marine-grade wires and connectors with ID tags
· Marine Breaker 360- Blue Sea Systems/main shut-off switch Charge system (2-way charging system for camper batteries)
· 2 x 120v outlets (kitchen and dinette)
· 2 x 12v outlets (kitchen and dinette)
· 2 x USB outlets (kitchen and dinette)
· Battery charger and 30 amp SmartPlug inlet
Lights
· 3 LED lights in the main cabin
· We replaced the light at the dinette w/multi-color dimmable LED light
· LED under cabinet light in the kitchen area
· LED outside and inside the entryway
· Xenon reading light in bed area
· LED swivel light in storage area
Lift Mechanism
· Hydraulic system with manual override and remote control
· Electric wire connection to truck/camper to charge batteries with quick disconnect
Flatbed
· Flatbed deck with LED lights and storage rear bumper
· Underbody storage boxes - qty. 4
· Slide out drawer
· Slide out ladder/mounting frame with quick-release
· Jacks to remove the cabin
Extra Options
· Additional solar panel 155 W
· Additional batteries (2) 300 AH AGM 6V ea (300 amp 12V)
· Battery monitoring system
· 2000w pure sine inverter with charger and monitor kit
· 1000w pure sine inverter with remote monitor
· Microwave
· 22" LED TV/DVD with mounting system
· TV outlet on driver's side
· Emergency repair kit with water pump
· Outside shower
· Dometic 9 ft. self-supporting awning
Truck Options
· ARB front bumper
· Hella Rally 4000 driving lights
· Winch 12000lbs with synthetic rope
· Extreme Air air compressor with tanks, hoses, dual outlet
· Back up camera, rear and front
· Tire package installed
· SUSPENSION UPGRADED – originally came with air bag suspension and we had it upgraded by Deaver Spring (deaverspring.com) to springs and it handles so much better!
· Fridge connection to truck (12v plug + quick disconnect) ARB fridge tie-down kit
ThatNewGuy
Do you have any pics of the truck?
Also what year is the Nimbl?
Nimbl is from 2014, however it was sold to the first owner in early 2015. I don't have any additional pics for the truck at the moment, I can post more videos once I get back to Florida. What specifically do you want to know/see?
Perhaps I am missing something? The only truck-specific pic I see is of the odometer. Generally buyers of any vehicle would want to see any number of pics of the vehicle including all interior angles, seats, rear seats, front and side exterior, engine bay is a plus as are undercarriage pics and any damage or dents pics. But again maybe I am missing something as your reply seems to suggest these are available. Apologies if so.
ThatNewGuy
No need to apologize, and of course you are correct. As I mentioned in the original post, I'm traveling internationally, and therefore unable to take additional pics right this moment. I will take more pictures and videos as soon as I'm able. In the meantime, I'm happy to answer any questions about the truck and the camper.
The truck is in a good condition, I would say much better than average 10 year old truck. I have all the maintenance records and receipts for the work done. No damage to the interior, one small (quarter size) dent on the drier's door. No rust, as the truck spend most of its life in California.
