SOLD - XVENTURE XV-2 with RTT, 2015
ChetRipley
Selling my 2015 Xventure XV-2 trailer with tons of options in excellent condition! Family has grown and we are looking for a bigger camper.
$15k in MA.
This is an incredible setup for going off-the-grid and can haul a ton of gear with you. Really a very unique and incredibly well-built trailer!
Also seen here. https://boston.craigslist.org/sob/for/d/norwood-xventure-xv-overland-trailer/7630491461.html
STANDARD EQUIPMENT
* All Aluminum Construction using patented huckbolt system - checkout the Xventure website, this thing is a tank!
* Large Front Storage Cabinet – 62 wide x 22 tall x 19 front to back. All Aluminum.
* Multi-Axis Max Hitch.
* Electric Drum Brakes.
* Dual independent manual Brake Controls.
* Break-Away brake actuator.
* Power Distribution Center - Completely wired with 6 fused switchable supply ports.
* Wiring harness runs through chassis tubes for optimal protection.
* Cargo bed mounted 12VOLT receptacles.
* Line-X Coating - Cargo Bed Interior and Front Exterior Wall, Chassis, Fenders, Storage Cabinet
* Rear 2" accessory receiver.
* 2: Rear D-Rings and spare tire mount.
* 10 Year Warranty on Chassis.
ADDITIONAL INCLUDED EQUIPMENT
* 2021 Tuff Stuff Alpha 4-person Roof Top Tent ($2500 new) & Annex ($600 new) - this thing is amazing!
RTT
https://tuffstuffoverland.com/collections/hard-top-tents/products/tuff-stuff®-alpha-hard-top-side-open-tent-gray-4-person
Annex:
* Elevating cargo rack (80/20) with gas shock lift assist - allows you to fit more on the trailer like an ATV
* Oztent Foxwing Awning w/ 3 zip on walls - such a great additional option and creates a semi enclosed area for hanging out and cooking.
* Goal Zero 60Watt Solar panels.
* Deluxe Lighting Package: 6 Rigid Lighting area lights. 4 Rigid under bed rock lights. 3 Rigid in-bed lights.
* Galley Table w/ sink & faucets - All Metal, 89" x 18" folding
* Hard folding tonneau cover.
* Built in water pump but NO built in water tank, this was a non-Xventure upgrade. High-end RV pump and PEX tubing installed via standard Xventure routing. However, rather than mess around with a built in water tank that needs to be winterized, I set it up to use 5-gallon containers. Works great for sink + shower.
* Water Heater (Propane) w/ shower.
* Propane Tank (20 lb).
* Toyota TRD 16" Rims with KO2 tires
Without the RTT and additional extras, the trailer is over $21k new, http://www.schuttindustries.com/XVENTURE/XV2
Asking $15k - great deal (replacement cost would be ~$27k). You will never find a trailer that is so well built and versatile. Selling because family has grown and we need something bigger. But will be very sad to see it go.
Mcoleman
