sold
magic tingles
10 25 2024 Sold for asking
10/19/24 SALE PENDING Summary: (reached 10,000 character limit, see follow up replies for rest of listing)
Turn key ready
Current location is Palmdale, CA 93551
Massive solar/battery/inverter system works great extended, off grid boondocking especially with the DC fridge and electric (AC) water heater, almost never need to fill propane (adapter for external tanks too)
Four wheel drive, lifted and high clearance. Goes where other RVs cant (more than many cars/trucks too)
We've owned this RV for 5 years and there's a lot of stuff that's gone into it
Writing this listing has been a lot of work, we've completed it to the best of our ability
Everything is as accurate as we know it to be, but may have some mistakes or omissions
162+pics and vids most taken 10/7/24, a few older ones showing internals, lights, awnings and in use
Purchased Oct 2019 with about 57400 mi
Used extensively by us only for about 4 years (owned for 5), hasn't been used since we got a truck camper last year
We've only needed/used 4wd 2x in all the years; heavy, wet snow/mud and dropping both front wheels in a rain rut at same time. No probs in deep sand w 2wd
Tons of upgrades to this
Spent tens of thousands of dollars on it and countless hours tinkering
Tons of storage with many wall nets, hooks, baskets, clips cup holders, clear bins, lazy susan, d-rings for lashing items inside on the floor
Has spent most of it's life (as far as we know) in sunny, dry California
It has been well used across the mountains and deserts of the west coast and has bumps and scrapes from doing do
No slides to break or cause other problems
3 sleeping areas, rear is slightly smaller than queen, as is cab, dinette smaller
House is full of tinted, single pane windows, lots of light, screens are good
Has expected wear and tear for a 26 year old vehicle
Never been in an accident to our knowledge
Full sized spare under cover
Clean California tile in our name
No smog due
Current registration and insurance thru progressive (70k stated value, ~$2200/Y)
Zero interest in trades
It's been our main hobby
Basics:
Chassis:
1998 Ford E-450 Super Duty Stripped Cab Chassis
Year: 1998 VIN (Vehicle Identification Number): 1FDXE40S5WHA87151
Mileage: 81,603 as of 10/7/24 (only increasing for test drives)
Model:24D 4x4 E450 SUPERDUTY TRITON V10
FIN 751DW7730372 (fleetwood identification number)
V10 - 6.8L 415ci GAS MFI 2 valve SOHC
SK (Salem Kroger 4x4 Conversion, Shift on floor stick for 4WD engagement), was told it was F250 front drivetrain from similar year & Dana 60 axle when doing maintenance over the years
~50gal fuel tank
6-8mpg
about 14000lb wet
House:
1998 Fleetwood Jamboree 24D
24ft
Roof mounted Air Conditioner
Onan Microlite 4000 (3300w?) gasoline generator plumbed into main fuel tank
~30 gal fresh, gray and black tanks
~30 lb onboard propane tank
Propane Furnace
Propane Range and cooktop
Rear observation camera
Rear airbags (we never used)
Chassis add-ons/upgrades/repairs:
Complete New Air conditioning system Fall 2023 by Ford Dealer in San Diego
New Heavy duty fan clutch (we believe) installed by dealer)
New tires
New/remanufactured entire brake system
Banks Power Stinger exhaust system an transmission tune (changes shift points?)
New emergency brake
New blend door (heat and ac)
New leaf springs and Bilstein shocks a few years ago
Has about an 8inch lift
Large front mud flaps with stainless steel weights/accents
Fabricated rear mudflap system (front and rear)
Front and rear sway bars (Roadmaster?)
Rear triple receiver with giant custom platform rack (all kinds of attachments (not pictured) to allow other hitch products to be mounted to rack)
Smaller triple receiver rack platform (not pictured)
Front hitch receiver (heavily reinforced, a $1200 fabrication job)
Brake controller for towing Teknosha Voyager
Dual rear jerry can holder (lockable) bolted and welded to rear bumper
(2) 5 gal jerry cans with nozzle
Front grill mounted observation cam
Viper 2 way smart alarm with text/email/app alerts and proximity sensor cost us $1800 (2 way internet control requires subscription arm/start/tamper alerts)
Atoto S8 Android 10 Head unit radio with front and rear cameras on touch screen (and any other apps you want)
54in high power curved front LED light bar
(2) Yellow front mounted fog lights
Replaced roof mounted (front upper) driving lights w all in one LED units
Front grill mounted amber "raptor" lights
High power led backup light bulbs/new lenses?
Ford OEM locking gas cap
Quick disconnect (negative) battery terminal
Bus bars on chassis battery
Regular fluid and filter changes
Chassis battery about 2 years old
Radiator recently deep flushed/cleaned w new coolant (3+hr labor)
Many gaskets replaced over the years, no known fluid leaks
House add-ons/upgrades/repairs:
1200W Solar Panels (6x200)
3000W Victron Multiplus Inverter/Charger
400 Amp hours of lithium batteries (3 Valence uxp 27? 130AH each, no bms, heating or temp, multiplus has low volt cutoff, batts are inside chassis and not exposed to outside)
4/0 AWG cabling
Victron bluetooth dongle for multiplus
Victron BMV smart shunt (bluetooth battery gauge)
Victron smart solar controller (70A? deets in pics)
Victron Orion smart DC-DC charger 30A
600 Amp Bluesea main cutoff switch
Progressive EMS hardwired surge protector with remote display (nothing to steal like external ones)
Precision Circuits LI-BIM 225 Amp Lithium Battery Isolation Manager (two way charging)
New genuine Onan carb for generator
Unique DC Compressor 6cu ft refrigerator (no AC needed, takes about 60W, doesn't need to be level to work)
Swivel adapter front passenger seat is very comfy and opens up the space
New Manual awning with zip to remove screen shade (can be ground anchored, adds a lot of strength)
(2) Window awnings (we almost never used)
(5) Blackout top down bottom up window shades
Replaced broken latches on some windows with hard to find metal aftermarket ones
Spring to keep screen door shut
RV bugstop screen door latch cover
AC heated mattress pad, takes about 80w, this thing is great, almost never need to run heat
Electric (AC) and Propane hot water heater
Stainless Furrion 30A power outlet
Gopower transfer switch
Switched 12v Heated tank pads on all three tanks
Switched 12v heated tape on fresh water supply lines
Complex thermostat controlled system for heated pads and tape
Switched computer fans (3?) to circulate air near water lines in rear of vehicle
External stay n play inline propane adapter allows use of external tanks
Hardwired dash cam (aukey 4k)
(8) Mictuning rock lights w bluetooth, infinite colors, really cool, 12+ hours to install underneath
Usb Fairy lights across ceiling
All interior lights changed to LED (most have switchable cool/warm hues)
Exterior Porch light LED
Switched rear led light inside larger passenger side rear storage area
Lots of usb chargers throughout
Marine power power covered pos + neg terminals for clamp on high power draw items (compressor, etc)
Powered , crank up OTA TV antenna (installed, tested never used + tv mount, we removed TV)
Stick on solar motion lights on outside (switched on unit)
Trick-l-start trickle charger house->chassis (currently disconnected? as BIM handles this)
New water pump
Oxygenics shower head
6 coats of elastomeric roof coating (no known leaks)
High end gold windshield shade and 2 front window shades (privacy too)
Full set of hand trimmed reflectix window coverings for cold weather camping
(2) Roof vent covers (maxair?) allow you to keep open during rain and while driving
External, water resistant rear power ports (12v sae, 12v socket, 2 AC outlets, starlink cable pass thru)
Replaced all compartment lock cylinders with ones that dont take a universal rv key
Numerous clear bins for organization that are appropriately sized for the shelves they reside in (a few hundred dollars worth)
Numerous wall nets throughout house (a few hundred dollars worth)
Low height d-rings for lashing/securing large items inside for travel
Lots of magnetic mounts chassis driver area for TPMS, phones, trailer cams, or other devices
E-track and straps
Lots of extra bus bars, and fuse blocks throughout
We've utilized almost every square inch of space for storage
magic tingles
Things that will be removed unless negotiated with sale:
Weboost powered cell booster w spliter and 3 internal antennas, $800 retail?
Alfa powered wifi booster, $250 retail?
Hardwired radar wiring for Uniden R3 w stalk mounted mute switch $100 retail?
Ring car cam, $250 retail
Amp-l-start trickle charger (house->chassis), $100 retail?
Other things that we used with RV that could be sold with:
Victron MK3 USB thing to program multiplus, $100 retail?
TST color TPMS and temp display with flow thru external sensors (dont have to unscrew them) $400 retail?
Roadmaster Nighthawk tow bar for flat towing, nicest one they make w led lights about $1000 retail
Mesh screen that attaches to tow bar to prevent debris from hitting vehicle, $400 retail?
Roadmaster dual drop receiver attachment to level out tow bar since receiver so high, $200 retail
(2) Joe hauler motorcycle carriers, $550 and $1000 retail?
Known issues:
-Dragged rear corner exiting steep sand wash a few years ago, pulled it back together, been fine for years, some paint cracking
-Rear ladder vertical has dent (pre-existing since 2019, has not caused any probs)
-Chassis AC will disengage under sustained high load or temps (was told by ford dealer this is by design to preserve engine)
-Shower pan has some cracks in fiberglass, we glued, seems to work, could be replaced if wantend
-Backed into branch, exiting shelf road, upper rear trim piece repaired to prevent water intrusion(about 6in)
-Opposite top corner cap appears to have crack, could be repaired
-Backed into front grill with new rv in driveway :(, epoxy repairs but raptor lights and front camera are hardwired in, doesn't flop around or cause any issues other than cosmetic
-Hydraulic leveling system worked when we tested in in 2019, we have not used or needed since, just use blocks or rocks, compressor frig doesnt need to be level. We had rig lifted. Selling as untested. We will not allow anyone to test it as we don't want to do any repairs on it should it fail. New owners may do as they wish with it
-Water pump leaked a few years ago, it caused some paint damage where water was leaking out of sides, still looks ok, water pump was replaced once we found source of leak
-Desert tan gel coat paint about 5 years old, still shiny and in reasonably good shape some cracking on rear back exterior wall, scuff marks and pinstriping here and there, prior owner mentioned blemishes can buff out
-Woodgrain dash cover lifting and damaged in places, common issue, there are fixes for this
-Top of house slightly pulled away from top of chassis cab. Replaced self tapping screws with nutted fasteners, washers, plates, likely stronger than new. Major job, zero problems since this repair was done a few years ago
-Screws for E-track were too long and pierced exterior front driver wall, left alone, has been this way for years
-Could use some re-caulking around seams, window frames and other areas, overall in decent shape
Original seller's description when we purchased on ebay in Oct 2019
It's not entirely accurate (ie mattress sizes, mpg, satellite dish are a few things and it has changed since we purchased it)
Condition: Used
Seller Notes: “*** PLEASE SCROLL AND CLICK ON ITEM DESCRIPTION to all the details and the 100+ pictures!Unique Layout and Super Clean camper*** This coach is pristine!!”
Mileage: 57400 Model:
Leveling Jacks Included: Yes Sleeping Capacity: 6
Fuel Type: Gas For Sale By: Dealer
Awnings: 1 Air Conditioners: 2
Vehicle Title: Clear Make: Jamboree
Type: SELFCONTAINED ALL TERAIN CAMPER Length (feet): 24
Custom FULL BODY PAINT, Hydraulic Leveling JACKS Front&Back, IN-MOTION Satellite Dish, 3 Solar Panels. 2 inverters one 3000W and one 750W for the TV (converts 12V from 3 coach batteries to 110V). ONAN 4K MICROQUIET by CUMMINS GENERATOR (THAT TAKES GAS FROM THE GAS TANK), , Rear HD Camera with night vision, SMART HDTV- with its own inverter, you can watch tv from the 12v battery, Pioneer In -Dash Stereo with Bluetooth, Mp3, USB, Aux input, LED lights in & out, FORTRESS GUN SAFE (WITH ELECTRONIC LOCK) Removable Tow Hitch Mounted Luggage Carrier. Look at the details and finish and you’ll see why this coach is special. FULL BATH (WITH SHOWER AND TUB), , HAS THE DUCTED CENTRAL AC AND FURNACE, SO IT BLOWS AIR EVENLY OUTSIDE SHOWER, , ENTERTAINMENT CENTER, ALL 6 BRAND NEW FALKEN OFF-ROAD TERRAIN TIRES, NEW BRAKES, NEW SHOCKS. ! It has the Firestone air Suspension, you can adjust your ride as you desire, also helps the coach not to swing on the freeway when is windy!Fleetwood quality and craftsmanship is second to none! ALL INTERIOR CABINETS ARE FULL WOOD!GORGEOUS FLOORS, UPHOLSTERY, ROOF WAS JUST RECOATED, NEW AWNING WITH ALUMINUM COVER. Why buy a Sportsmobile van that offers a lot less???
THE CUSTOM PAINTED EXTERIOR SHINES AND LOOKS LIKE THE NEWER 4WD MOTORHOMES,!! NO MORE WORRYING ABOUT VINYL FADING!! YOU CAN BUFF IT LIKE A REGULAR CAR FOREVER! SHORT, YOU CAN PARK IT ON YOUR DRIVEWAY, YOU CAN DRIVE IT ANYWHERE, DRIVES EASY.
We had it inspected bumper to bumper by a reputable 3rd party - Inspection report shows all in perfect order. Also all interior functions have been inspected by an RV Specialist (30 days warranty on the Coach part). Everything works, as it should, COMES WITH SMOG CERTIFICATE. IT IS READY TO GO ACROSS COUNTRY.
Built on a Ford E450 Chassis, LEGENDARY TRITON 6.8l V10 THAT IS KNOWN TO GO FOR EVER, AND CHEAP TO MAINTAIN (THEY USE THE SAME ENGINE ON THE BIG 38 FEET CLASS A BUS TYPE RVS!) PAIRED WITH AN AUTOMATIC TRANSMISSION WITH OVERDRIVE, GOOD FUEL ECONOMY 11-13MPG (AND YOU CAN GO INTO ANY CAMP WITH IT!! DRIVES AND FEELS VERY SOLID, Tilt, Cruise Control .No issues, No leaks, No strange odors, No pets, No smoking, Smooth Ride!
PERFECT LAYOUT, FOR A FAMILY OF 6, AS YOU CAN SEE, THIS COACH FEELS MUCH BIGGER INSIDE, THE LAYOUT MAKES THE BEST USE OUT OF EVERY SINGLE INCH AVAILABLE. REAR QUEEN BED, KING SIZE BED ON TOP OF THE CAB, STILL HAS A FULL PRIVATE BATHROOM WITH SHOWER AND TUB ANDTHE DINETTE CONVERTS INTO A BED.
This unit will sell fast, AS YOU CAN SEE, IT LOOKS BETTER THAN MOST SIMILAR AGE OR NEWER RVs!! It was used, loved and cared for all its life, LOTS OF MONEY INVESTED TO KEEP THIS BABY CLEAN! Why pay $180000 for a new one??
Tdavis8695
