SOLD
A&Mbronco
Selling my 1999 100-series to fund another project. I've owned it for close to 10-years and its been a great reliable truck from daily driver to offroad and camping. It's a 99 with factory rear locker, ~187k miles, and extensive baseline maintenance done. Good rust free truck, originally from TX. Located in Denver, CO. Asking $20k
Modifications:
  • TJM front bumper with Warn winch & Baja Designs LP6 lights
  • Dissent rear dual swingout bumper
  • ~2" lift with Dobbinsons MRR rear shocks and IMS front shocks. Ironman control arm reinforcement
  • Trail Tailor front upper control arms
  • 285/75r17 Ridge Grappler tires on Method Wheels + matching spare
  • White Knuckle offroad sliders
  • ARB Hard Cased Awning
  • Custom rear drawers & selectable light on hatch
  • Tailgate storage panel
  • ARB air compressor
  • Slee Group 31 battery upgrade-Blue Sea fuse panel and disconnect under the hood
  • Wired for 12v fridge with Ben3D mounts
  • Pioneer head unit w/ Carplay
  • Scan gauge with overhead Ben3D mount
  • Extensive sound deadening
  • Front seat bottoms recovered in vinyl by previous owner
Maintenance Done:
  • ~152k: New OEM steering rack, CV shafts, radiator, ball joints, and diff drop bracket
  • ~162k: Replaced all control arm bushings (front & rear), Shocks replaced, sway bar bushings replaced, SS brake lines. All fluids changed (oil, break, trans, power steering)
  • ~167K: Replaced both drive shafts
  • ~172k: Timing belt, water pump, spark plugs, coil packs, valve cover gaskets, crank shaft seal, PCV replaced
  • ~184k: New group 31 battery w/ Slee kit. Front knuckles fully rebuilt with new bears and bushings. Replaced the main fuse block
  • I can send a full list of all maintenance performed under my ownership
Known Issues:
  • Sunroof is not functional - cables were seized and cut prior to my ownership
  • Driver window squeals and can be slow to go up when cold
  • Door lock actuator is intermittent, have replacements
  • Small chip on upper side of windshield
  • Lower rear quarter was damaged prior to my ownership, has been repaired and is fully hidden by the rear bumper
  • General paint chips, scratches, and small dents from use
2eleven
