So, long story short, I ordered the relatively new Camburg Ball Joint Upper Control arms for my 06 Tacoma 4x4 Sport. The replacement ball-joints listed on the vendor's website (Wheelers) are the Moog Units(Part # K80811) and are significantly cheaper via another source, which is the route I went. Removal of the existing UCA's went smooth (thanks to various posts), as well as separation of the existing ball joint/knuckle. I rented a ball-joint press (cup/clamp style) and proceeded to press the ball joints into the new arms. This took a tremendous amount of force in my opinion (ie. 24 inch breaker bar extension on ratchet to push them in far enough to expose the retaining ring groove. The first arm (Driver side) seated nicely, however a semi-circular "shaving" of metal was embedded in the retaining ring groove following installation. I removed this with a flat-tip and proceeded with the second arm. Following the same procedure, the second BJ was seated in a matter of minutes, however upon inspection, the "socket" portion of the BJ cracked during the pressing. Also, I noticed that following assembly, the stud portions of the BJ's are essentially impossible to move by hand, however I never really tried before installing them.
As I needed my truck road-ready tomorrow, I reassembled the stock arms, etc and am now left with a stock truck, two expensive Camburg paperweights, a cracked Moog BJ, and a hole in my garage wall roughly the size of a ratchet with 19mm socket. To add to my frustration, I reread the entire Camburg website and found a note specifically stating that Moog BJ's are not compatible due to slightly larger sizing intedned for use in stock stamped-steel UCA's. I find it hard to belive this note was there before during the 6 months I researched these units before buying them, but I could have overlooked it. More searching of various other Toyota forums yielded multiple mentions of using Camburg arms with Moog joints but no mention of any problems. Does anyone with more knowledge/talent/experience have any input on the following:
- Has anyone encountered this problem with the Camburg arms? Or perhaps successfully used the aforementioned combination?
- What are your thoughts on ordering a replacement Moog and having a shop remove the cracked unit and press in the new? I'm guessing whatever material came out (see photo) was what was required for the moog unit to fit and a second Moog should slide in easier.
- Excluding the Camburg arms, does anyone have any experience with the Moog K80811 units? Are they just stiff to begin with? Recommendations on other OEm replacemetns (Napa, Raybestos, Toyota?)
Any help is greatly appreciated.
