Is the speedometer electronic or mechanical?
Including the sensor, which would be on the rear output of the transfer case.
And if the system is mechanical, do you know your axle differential gear ratio? And what tire size originally came on your actual vehicle?
Because if the system is mechanical, itās possible that a speedometer drive gear or pair of little gears, original equipment for smaller tires but faster differential, will be correct.
The original differential ratio and tire size is often displayed on a plate attached to the āBā column of the driverās door opening. And/or available in the EPC system, which MB has made very difficult/impossible to access for private people.
For what itās worth, your 385s are about the same diameter as 11R22.5s, a very common size.
If on the other hand electronic, is the vehicle young enough to be hooked up to a Star Diagnosis computer?
Or maybe my post is irrelevant, perhaps thereās just a screw to turn somewhere near the dashboard.
My speedo / Tacho , which is slightly different, has a small rectangular seal type sticker on the plate behind the drop down clock face , It looks like an anti tamper sticker.
Once peeled of it revealed a very small hole and the screw was deep set in the hole .
Calibrating was a pain in the butt as you tweek it a bit and then drive. Tweet a bit more , backing off a bit etc..
I had 2 GPS devices on the go to compare with
It took many goes , so be patient View attachment 801977
I found that doing that calibration at quite high speed , maybe 100kph was far more accurate .
If you did it at say 50, once you got to higher speeds any inaccuracy had been magnified and it was way out .
Neil
It may say āelectronicā, butIt says electronic on the front of it
Neil
the speedometer calibration often involves adjusting a screw on the back of the instrument cluster or using a specialized tool.Hi! I am trying to calibration my speedometer for the new 385/65 22.5 wheels and tires. I'm not able to find this screw.. š any help appreciated
The speedometer calibration often involves adjusting a screw on the back of the instrument cluster or using a specialized tool. If you're sick and weary of the stress that comes with homework. It was during a particularly difficult semester that I discovered CustomWriting Service, and it has been a revelation. They offer unmatched comprehensive support to students who are struggling with their coursework. The writers' proficiency is evident in their assignments, which are intelligent, thoroughly researched writings. Meeting deadlines is only one aspect of the service; another is providing exceptional quality. Because of the affordable prices, even students on a tight budget can use it.
