sPod 8-circuit controller and touchscreens for sale $200 to $750
kcshoots
I have two sPod add-On Touchscreens and one 8 Circuit System BantamX Touchscreen for Universal mounting with 36" battery cables for sale. Touch screens are $200 each and the 8-circuit controller $400. Or all three for $750. New these are $1,275 plus shipping and tax. I'll mail them to you w/in continental US from Reno, Nevada at my cost. All are brand new, in original packaging. I bought brand new but never installed, but did open the packaging on the controller. You can use these to add to an existing system or for your new installation and control up to 32 circuits, 12 or 24 volt. The controllers are fully programmable and can be daisy chained via simple single wire to each of up to four circuit controllers and touchscreens on a system, and sPod has a downloadable app that can control each circuit wirelessly from your phone. More info:
The BantamX will save hours of wiring & installation time! It is a small, 8-circuit (expandable) control system that provides a clean (one ethernet cable into the cab!) and safe way to power and control 12/24VDC accessories. Due to the small footprint of the BantamX, the placement options are endless! No cutting, fishing wires into the cab or tapping into the vehicle‘s electrical system. It’s the perfect over-all solution for all your aftermarket electrical accessories with options unmatched by anyone.
• Fully programmable, digital controlled system
• 8 circuits rated at 30 amps at 12.5 VDC per circuit
• 16-position terminal block (easily attach accessories)
• 2 controller ports (RJ45) for Ethernet cables
• Integrated low voltage cutoff (LVCO) battery protection w/ optional override
• One ATM mini-style fuse for LVCO protection & reset
• Failsafe self-healing fault protection system (from 1.5 to 30amps)
• Current-sensing MOSFETs controlled by a microprocessor (no fuses & relays)
• 100 amp in-line fuse
• Nylon braided battery cables are hi-strand crosslinked copper wire with a silicone jacket
• Operates on 12VDC or 24VDC
• 8-position input terminal block for controlling outputs
• Built-in Bluetooth capabilities for remote control
• Protection against: overheating, over-current, shorts, reverse polarity & field collapse
• Ignition control and safety lock-out for switches 1 and 2 (optional)
• Up to 4 BantamX units can be daisy chained & controlled by the Touchscreens
• On-demand wireless software updates/upgrades
The touchscreen controller is small but packs a big punch! (3-3/4w X 2-7/8h X 5/8 thick) The control module is a 3.5-inch LED-backlit TFT LCD screen with a resolution of 320 x 240, 16.7m colors, and a viewing angle of 180 degrees housed in a billet aluminum case. The touchscreen comes with its own universal mounting bracket. The connection between the 8 Circuit System and the touchscreen uses a standard Ethernet cable that is 10 feet long. The sPOD Touchscreen is a resistive touchscreen.
Benefits:
  • Reduced installation time and labor allowing for mounting and connection of eight switches at one time versus individually.
  • Reduced wire harness complexity, using one harness to our controller to accommodate up to 32 circuits.
  • Reduced harness size offers an overall reduction in weight, improving the operational efficiency of the equipment.
  • Increase in switch lifecycle over traditional electromechanical switches.
Each switch is programmable for:
  • Dimming
  • Strobe
  • Flash
  • Momentary
  • Switch Linking
  • On-Road and Off-Road mode of operation
    Touchscreen Control Module Features:
  • Voltage feedback (vehicles battery/alternator voltage)
  • SourceSE/Bantam/BantamX board temperature feedback (shown on screen)
  • Customization: legends (3 lines of text)
  • Automatic backlighting off after 30 minutes of being inactivity
  • Automatic power off after 6 hours of being inactive or engine not running (Deep sleep mode)
  • One-touch off function
  • One second hold on-off button shuts all circuits down
  • Automatic system shut down when the touchscreen is unplugged
  • Backlight dimming
  • Multiple Source select (One touchscreen can control up to 32 circuits)
  • Come with its own mounting bracket.
IvaBru
