georgeofthedesert
I have been going through everything I could find on YouTube and the googles and I'm not finding anything that really eludes to suggestions or a lot of info for what I'm looking for, I understand the Starlink Mini was released and that is probably the main reason along with my lack of knowledge to gleam the right information from the stats that were discussed. But I'm wondering for the folks that are using the Mini, what are you doing for a power source? My overall goal is working while in spots with no power/internet since my wife and I work from home. The technical goal is to have a power bank and solar panel that can run the Starlink Mini and recharge laptops a couple times a day (MacBook and general HP laptop), and that's all this power bank will be doing. I have a FourWheel camper to power/charge everything else and that power source can be used for the laptops/Starlink as well, it has a 160W solar panel to charges it's own 6vAGM (x2) batteries. However since that setup runs the fridge, lights, charges cell phones at night, etc. I would like to keep the laptops and Starlink off that source. Since this is mainly to use for work it will be used during the day, 8 am - 5pm, while the sun is out so I'm hoping solar would help keep the power bank from draining too much. With that being said my initial thoughts are a 1000w bank (Jackery, Anger, Bluetti, etc.) with a 100w portable solar panel. Does that seem reasonable for the goal? With the Starlink Mini using a bit less power than the full sized setup I'm questioning if that size of a setup is needed, or if I'm way off and it isn't enough.
I know the laptop side of the equation is the main power consumer in this situation. So it might be overkill for the Starlink side, but not enough for the laptop charging side, or it's OK for either but not for both. So I'm looking for a bit of insight to see if my plan should be adjusted.
