Starlink ROAM antenna options?
Sid Post
Is the Mini now the only antenna available? What happened to the High Performance and the Standard antenna receivers? Is the Mini antenna really a replacement for those in Vehicle and Remote installations that are not commercial?
Sid Post
How do those two compare? I was looking at the High Performance version for my Overlander before things went haywire in my personal life with inflation and other COVID-related stuff.
crazysccrmd
They both work fine. Unless you’re running some kind of high bandwidth online business the high performance is absolutely unnecessary. The Mini is smaller, doesn’t require a separate router and still gets 100mbps and faster when I use it. The Standard will let you put the router inside your living space so the signal might be better but I’ve had no issues with WiFi strength and my Mini on the camper roof.
