Storing a Jackery/Lithium battery in a cold place
socceronly
Just want to double check, is storing one these things in a place that will get well below zero ok?
It's just you don't want to charge it when it is cold. Is that correct?
Thanks
JM
john61ct
Yes, defrost at least overnight, the center of the actual cells buried inside where the actual chemical / slurry are should be at least 15°C
unless you are charging VERY slowly.
25° if any kind of "fast" charging, but usually the BMS in these powerpacks don't allow that anyway.
And it's not just the battery, extreme freezing conditions may stress or break electronics, so check the manual or give TS a call if you're in Minnesota or something.
IvaBru
