mike the welder
I want to make my Suburban as reliable as possible and fix known issues before they become an issue. I plan on keeping it a long time and hate sitting on the side of the road. Please post any known or found issues you have heard of that can be proactively fixed or repaired. The way I figure $500-$1000 a year in proactive repairs and maintenance is cheaper than payments on a new truck.
I'll start,
Heater hose fittings and bypass valve. Theses plastic fittings become brittle and crack and break. I had the 'Y' fitting crack and leak shortly after I bought my Burb and it emptied the cooling system in a matter of minutes. I replaced most of the heater hose, the fittings and bypass valve for about $50 in a couple of hours.
New fittings and bypass ready to install.
Fuel injection spider. I have read the VORTEC SPIDER FUEL INJECTORS have issues as they age and cause hesitation and bad fuel economy. There is a upgrade replacement available. I plan on replacing mine shortly after Christmas because I do have some hesitation off the line and it's driving me nuts. I have read this is about a 2 hour process with regular hand tools, about $180.
Here is an article that explains the problem, benefits and procedure in converting your Vortec CSFI injection to MPFI injection.
http://www.fuelinjector.citymaker.com/Vortec_spider_fuel_injection_conversion.html
![vortec-spider-fuel-injector.jpeg vortec-spider-fuel-injector.jpeg](https://expeditionportal.com/forum/data/attachments/195/195930-62877bad6b12ce6d8e9cfd5eaf4bcc9a.jpg)
I'll start,
![SDC14447.jpg SDC14447.jpg](https://expeditionportal.com/forum/data/attachments/189/189971-258c1341caf946ae9c1982dab0b4f441.jpg)
