Tacoma ARE Camper Shell - Long bed - Windoors - Magnetic Gray - Yakima Racks - SoCal
theREDwonder
I have a 2011 ARE Camper shell, fully loaded! It has windoors on both sides and a flip down window on the inside, which is super handy for cleaning the back window of the truck and the inside window of the camper shell. All the locks are matched, so its just one key to unlock everything. It is the beautiful Magnetic Gray Metallic and shows very little signs of use, it looks brand new. The inside is carpeted with gray carpet and there is also a light on the inside. The power for the inside light as well as the third brake light are connected to the truck through a 4 prong trailer style connector. You will need to wire that in yourself. I have spare keys for everything. The windoors are absolutely my favorite part, you can open them up and pretty much reach anything inside. The yakima cross bars are mounted on yakima rails, so you can slide them around if you want. The yakima bases are keyed so no one goes walking off with them.
This setup was purchased new in 2011 for $2500, I have the receipt to show you if you really want to see it. It uses 4 clamps that slide into the utility track, so no drilling required for mounting.
Should fit pretty much all 2nd and 3rd gen Tacomas with a 6 foot bed. Might fit
I am asking $1,500, located in Huntington Beach, CA near the harbor.
I will happily help you install this on your truck, but bringing a friend would surely speed it up.
banshee01
