Tacoma Flip Pac mounted to a Tundra?
beneng_jr
I have the opportunity to pick up a used flip pac thats currently on a 1st gen access cab tacoma. I own a 1st gen access cab tundra which is larger; bed width on the outside is 67.5", 61.5" on the inside between the rails (generous 3" rail width. The flip pac in question is just over 64" wide so it seems like it should fit on the rails.
Anyway... anyone with flip experience have any recommendations against this?
Arclight
SAR guy
I'm pretty sure this won't work. The Flippac on my T100 is the one you would use for your Gen-1 Tundra. It's the smallest truck that uses the "full-size" Flippac. On our trucks, the shell is a bit wide and hangs over, with the inside rails adjusted to fit the bed. On the Tacoma model, the shell is just a little narrower than your bed rails. If you wanted to really check, you could come do a test fit on it. Also, measure the cab height and front-to-back. I think the bed is slightly longer on your truck than the Taco.
Arclight
iStan814
