TDK Trailer For Sale - Overland Explorer Vehicles $28,500USD/$38,500CAD
2018 TDK trailer for sale. 2018 production run. Customer cancelled unit. Never been used. Trailer has options (listed below) already on it, included in this price, but also options still available for an additional cost.
Specifications:
Body Dimensions: 130" L x 48" H x 60" W
Overall Dimensions: 178" L x 88.25" W x 75.5" H
Weight: 2145 lbs. (dry)
Tongue Weight: 215 lbs. (10%)
Frame:
CNC Laser Cut Steel Tube Frame with a 2 Step Powder Coat Finish
2" Receiver located in the Front and Rear of the Trailer
Max Coupler Multi Axis Receiver (6000lb rating)
1.5" HSS tube keyed into the frame to make up areas in front and behind fenders, topped with aluminum checker plate powder coated with antiskid (black)
Fenders are 1 piece formed aluminum - powder coated antiskid (black)
(2) Stabilizer Legs located at the rear, these are round tubes that have been drilled in a helix pattern to obtain hieght changes in 1/2" incriments.
Spare Tire Mount location on the front of the TDK to be bolted onto the front storage tray, will work for both a 33" and 35" tire.
Suspension:
Timbren 3500 Independent Axles w/Electric Brakes and Dampening Shocks - comes with 6 bolt pattern
2 - 33" (285/70R17) BF Goodrich KO2 Tires E rated w/PROCOMP Wheels La Paz Series 29 (6 x 5.5 bolt pattern)
Body/Cabin:
1.5" Foam Core Hybrid Composite Wall Panel Construction - White only
Aluminum Extrusions - powder coat finish -White only
All bonding using tested adhesives - no mechanical fasteners
No wood products used
Left and Right Side Doors - includes tinted sliding window with screens
Body/Cabin:
Left and Right Side Doors - includes tinted sliding window with screens and lockable
Integrated Front Storage Cabinet:
Inside Dimension: 16" w x 48" h
Solid lockable access doors, on left and right side
Vented to the outside
Wall mounted cargo tracking for securing items
Aluminum battery tray capable of holding (2) Group 31 Batteries - comes with (1)- G31 battery
LED Lighting
Anderson Connector to be installed and prewired for a portable solar panel
Shore Power Plug located below the drivers side door
Aluminum powder coated mounting plate for future electrical items (such as an Inverter), this item goes full width and full height
Interior:
Inside Cabin Dimensions: 57" W x 80" L (fits a double mattress or custom mattress to maximise width)
(2) Sietz Windows (dual pane acrylic w/retractable screen and blind), one for each side of the cabin
Cargo Tracking on left side and right side for mounting 10" x 24" soft storage bags (located on our web store)
(2) Aluminum Cabinets with a storage tray between them
Star Board Polymer Doors with cast aluminum positive close latches
10 speed Maxair Cabin Roof Fan
4 position Bluesea 360 DC Breaker
110V outlet prewired
USB 12V connections
LED Lights
Exterior:
Exterior LED Lights - one on each side above the cabin door
OEV Custom Aluminum Roof Rack - powder coated (adds 6" to overall height w/33" tires) includes (5) spanner bars, will hold Alu-Cab or similar awning. This will accommodate any RTT on the market.
Propane Cabinet designed to house 2-10lb Propane Tank, mounted on the rear driver side of the TDK, includes manifold, regulator, associated piping and (2) quick connects for bbq and gas stove. Manufactured with powder coated (white) aluminum, stainless steel hinges and aluminum positive close latch. Comes with 1-10 lb bottle.
1 - 22 gal Certified Potable Water Plastic Tank, Plumbing, 12V Pump and Skid Plate, this has been moved slightly further back of center of the axles to better distribute weight. The distance from grade to the bottom of the skid plate is ~18" on 33" tires.
Auxiliary water connection to be located at the rear of the trailer
Exterior Front Storage Tray (powder coated (black) aluminum with tie down points)
D.O.T Approved Exterior LED Lights along with reverse lights with a 7 pin connector at the front and a 4 pin at the rear
D.O.T Break Away System - includes chains
Drip edge above the cabin side doors and the rear kitchen door
Checker plate aluminum rock guard on the front nose
Rear Outside Kitchen:
2- Galley LED lights (18" long), one inside the kitchen ceiling area and the other mounted on the inside of the rear door
3 Piece Telescopic Slide Out Kitchen Cabinet: 1st drawer has a removeable sink, 2nd drawer has a storage area for a 16" two burner Partner Steel cooktop and the 3rd drawer is a utilty drawer. The water faucet is located on the slide kitchen counter top, accessible at all times.
2 position 12v USB plug
Slide out cooler tray with 12V (10 g wire) provision (max cooler dimensions: 30.5" W x 19" x 25"H)
(3) upper powder coated aluminum cabinets with star board polymer doors with cast aluminum positive close latches
Options on Trailer
Vinyl Window coverings
Go Power 1500W High Surge Inverter
Inverter Installation Kit DC 200
Go Power Smart Charger GPSC-12-10A
Climate Rite 5000 Installation Kit - 2 Ports Installed
Extra Group 31 Battery
Spare 10 lbs. Propane Bottle
EVA Foam On Floor Of Front Storage Cabinet
Options Available (Prices in CAD)
Spare Tire/Rim (Same as on TDK already) - $915.50
Blue Sea AC Breaker Panel - $545.50
30' Extension Cord For Solar Panel - $85.00
18" x 24" Outside Table (Fits In Rear Stabilizer) - $773.90
Alu-Cab Shadow Awning Mounting Kit (Raw Aluminum) - $395.50 ($720.50)
IMG_20190115_1501227.jpgIMG_20190115_1501576.jpgIMG_20190115_1504133.jpgIMG_20190115_1503556.jpgIMG_20190115_1503108.jpgIMG_20190115_1502185.jpgIMG_20190115_1502551.jpgIMG_20190115_1502338.jpgIMG_20190115_1502412.jpg
scotty59
