Temporary tow mirrors?
CSG
I'm thinking of using my Hundy to tow a small travel trailer on occasion and need some extension mirrors that will fit over the existing mirrors. I have a set of slip on ones I use with my GMC2500 but they are designed to fit GM. Are there ones to fit the 100 series LC/LX?
[ame="http://www.amazon.com/CIPA-11950-Clip-On-Towing-Mirror/dp/B00029WRKA/ref=sr_1_7?ie=UTF8&qid=1291486913&sr=8-7-spell"]Amazon.com: CIPA 11950, Clip-On Towing Mirror: Automotive[/ame]
I've used these a few times when towing my large travel trailer with my 4Runner. They are 'universal' fit (can't find anything made specifically for the car), vibrate quite a bit and are far from perfect. But for the limited use they see and the inexpensive price they have worked.
I should call them Monday (CIPA) and see what they've got. I have a set of their slip on mirrors for my GMC and they work well. These are a little more mickey mouse looking. But if they do the job...
The ones I have are not great by any measure, but I have not found something better for my 4Runner, therefore they have won by default.
I'm generally very picky about things like mirrors & driver set-up. I want my mirrors clear, clean, as vibration free as possible. Most stock mirrors meet this criteria, many aftermarket do not. These things vibrate and move lots, as you might be able to deduce from the design/mounting arms. They are also not quite long enough to see around the side of a large trailer, particularly on the passenger side. With your slightly wider 100-series they should be slightly better than on my 4Runner. I'm only recommending these because you can likely make them work if there is no specific mirror extension made for your platform.
mbobhat
