Howdy all,
I would like to preface this question by first thanking all of you who are active in this forum and the Portal in general. You have been so informative and willing to share your knowledge. You have definitely shortened my Toyota truck learning curve!
I have a question about adjusting the Torsion bars on my new T100. The previous owner had an add-a-leaf installed when he put on his camper shell. I believe the shop then cranked the torsion bars up to match the rear ride height.
I would like to relax the bars so as to improve the ride quality. I noticed that there was very little (less than a fingers width) of distance between the droop stop and the A-arm (the compression stop had 2 fingers of gap). I began backing off on the adjustment bolts equal amounts per side and measuring the rim to fender distance. I was able to drop the drivers side 1" with only 4 revolutions of the bolt. I have turned the passengers side 9 revolutions and it has only dropped 0.75". I now see a lot less bolt exposed above the nut on the passenger side bar.
Am I missing something here? Could something be seized up in my suspension?
Thanks,
Brian
Thanks,
Brian
