the Compressor build, need some input
GJK5
Just bought this mid build from someone local, thought it looked like a tow behind compressor......
Structure is done, solid frame, needs door and drawer completion, some paint and some interior trimwork to clean it up but solid trailer. All riveted steel panels, very sturdy frame and body, Timbren axle-less set up, CU Off Road Max Coupler, 21 gal water tank in enclosure over axle, level jacks on 3 corners and 3 35's. Going to do kitchen slide on starboard small hatch and big gear slide on rear door, middle shelf all the way across, kitchen and bar gear on Sb'd big door and living area gear on port for RTT annex access. Planning on at least 100W solar, charge controller, inverter, deep cycle, pump, instant hot and shower as well as kayak rack up top.
Would love input on DIY drawers, 12v/110/solar setup (will also be toting an EU2000i for backup) and propane distribution system. And paint, not sure if I want to do automotive paint or some sort of bedliner.
My tow vehicle.....
Jlbeats
