SoCalMonty
Hello from SoCal!
I was at a shop getting tires installed when a VERY clean FJ60 pulled in...
...but I had noticed when he pulled in, (1) that engine sounds a bit different, and (2) that tailpipe seems a little larger than stock. I started talking to him, and it turns out he had this under the hood...
...turbo diesel in SoCal!
He has owned the truck since new, and it's not a daily driver anymore. Turns out the swap was a nightmare. The shop that did it was in the Los Angeles area...it was something like "Mar-Z-Pan" or Mar-Z-Ner"...it was hyphenated and started with an 'M', that's all I remember. Anyway, it turns out (1) they told him it would be smog legal in CA, which it isn't, and (2) the engine they installed is bad, with major corrosion in the block. He's had it flushed dozens of times to try to get the corrosion out, but the block is eating itself from the inside out so it's on borrowed time. That shop is not admitting any fault, and the guy is out a lot of money with an FJ that has a bad motor which he still can't seem to referee or register yet.
So...just posting the cool sighting, and be careful with that shop in LA if you know the one I'm referring to! See you in the dirt!
