Bikersmurf
I've got an intermittent crank/start issue. I've got a 97 Crestline Ambulance, 7.3 PSD, north of 325,000 kms (discovered Odometer didn't work after buying). Once in a while, turn the key, wait for 'wait to start to go out', turn to crank position and nothing happens. Thump the dash above the Speedo on drivers side and then she'll crank instantly (if holding key in crank position) or when I turn to crank again.
It was doing it before I replaced the original, and dead, alternator. I thought the problem was solved until the other day, a few weeks after, when their was a momentary pause before it cranked, and then today it needed a thump 3 out of 5 times I started it. When it works, I can shut it off and restart it, but after sitting it acts up.
Plan so far
1) it needs a fuel bowl 'rebuild' and I plan to also replace filter... Their are fuel leaks in the valley, and replacing all the orings and looking for anything else leaking at the same time. Water in fuel light is on before it starts, and pulling the drain lever hasn't changed anything.
2) open up the dash and figure out why the odometer isn't working.
3) look for loose conections behind the dash before it leaves me stuck.
Any tips, pointers or things to look for or check?
Plan so far
