Timbren 3500 off road suspension, new with boxes opened but never mounted. I have the receipt from etrailer.
Decided cutting off my old suspension would do too much damage to the trailer so I went a different route. My indecision is your gain.
Located in Dallas area, will ship if you pay but rather do local pickup.
PM or text at 21four-4zero5REMOVE-234one
(sorry for the weird phone number, too much spam)
Manufacturer description below:
etrailer.com/Trailer-Leaf-Spring-Suspension/Timbren/ASR35HDS01.html
Timbren Trailer Leaf Spring Suspension - ASR35HDS01
Axle Replacement System
Axles
Universal Fit
3500 lbs
Timbren
Spindles Only
Designed for off-road tires, the heavy-duty Axle-Less system provides a smooth, quiet, safe ride and can eliminate the need for an axle. Suspension units with brake flanges replace your existing axle and operate independently. Fits any frame width.
Features:
Suspension system provides a safe, smooth, quiet ride for your trailer
2 Separate units replace your existing axle
Oversized components are ideal for off-road and heavy-duty applications
AEON progressive-rate main springs absorb road shock and support trailer's load
Deliver a smooth, stable ride, regardless of load size
Compress and become stiffer as load increases, boosting spring strength
Rebound springs act as return devices to minimize rattle and bottoming out
Create constant pressure on the arm, so the suspension is never completely relaxed
2 Independent units can eliminate the need for a thru axle
Increase ground clearance
Lower deck height for easier loading and unloading
Reduce roll during cornering
Fit any trailer width
Built-in camber and toe-in help your trailer to track straight, reducing wear on the tires
Straight, EZ Lube spindles accept trailer hubs (sold separately)
EZ Lube feature makes it easy to grease bearings without removing the hub
Spindles can be removed from units for simple replacement if damaged
Heavy-duty steel construction with black powder coat finish resists wear and corrosion
Easy to install and align
Bolt or weld to your trailer's frame
Specs:
Fits: 1-axle and 2-axle trailers that use low-pressure, off-road tires
Not recommended for triple-axle applications
Weight capacity: 3,500 lbs
Brake flange bolt configuration: 5 bolt
Quantity: 2 suspension units without hubs
Works with 5,200-lb, 6,000-lb, or 7,000-lb hub and drum assemblies (sold separately)
Spindle/hub compatibility for 5,200-lb hubs/drums:
Bearings: 25580 inner/LM67048 outer
Seal inner diameter: 2.125"
Spindle/hub compatibility for 6,000-lb hubs/drums:
Bearings: 25580 inner/15123 outer
Seal: 2.125 inner diameter
Spindle/hub compatibility for 7,000-lb hubs/drums:
Bearings: 25580 inner/14125A outer
3-Year limited warranty
Axles
Universal Fit
3500 lbs
Timbren
Spindles Only
Features:
Specs:
