Tires... I am due for set. What are you rockin' on your Gen 3 Monty?
Skidmarkart
Guys, I am going to be due for a set of tires shortly. I am curious what you are using. My Gen 3 is all stock, but I'd love to put the biggest, nastiest option I can.
TIA for any advice!
nwoods
Max size using stock wheels, no lift:
265/75/16 - 31.7" and commonly found
275/70/16 - 31.2" diam
275/75/16 - 32.2" diam
285/70/16 - 31.7" diam
285/75/16 - 32.8" diam
Stock size is 265/70/16 - 30.6" diam
I went with the 265/75.16 on Falkien Wildpeak AT3's, and I really like them. Quiet on the road, superb in the rain, excellent off road.
MoabRefugee
Running KO2’s in 265/75R16 Load E. I would by them again, but plan to go to 285/70R17 in order to go Load D. These will be plentiful and cheap as they are the new OEM fitment on JL Rubicon’s. I can go 33 and save a few #’s over the Load E’s. If they made it, I would have opened my wallet for 255/85R16 KO2’s. The General ATx interests me and has a Mileage Warranty. I am most likely sticking with BFG. Lots of really great tire choices out there, and IMO 265/75R16 is plenty unless you want to go 4.9(as I do).
rhoyle
I’m currently on 265/75R16 K02s. They’re great tires but they’re more than I need, especially in Load E. What do folks recommend as a “step down” from the K02 but staying on the 16 inch rims? Not a highway tire, but slightly less aggressive than the BFG and not as heavy?
plh
Nothing bigger than 265/75R16 (or 265/75R17) without a lift. I am a fan of BFG A/T KO2. Not sure how the Falkins are with the re-design, but I ran the early model of these tires (Wildpeak A/T) and they were very loud on the Gen 3 chassis.
Ocdfisher
I'm also running 265/75/16 e load ko2. A little stiff on the road. They are like 21 lbs heavier each than a "stock" tires. I feel it does make a difference in braking.
Skidmarkart
Thanks all! This is fantastic info.
I've been running a set of Wrangler (SRA, I think) tires I got at Walmart (due to a blowout I had on a road trip, and I needed tires anyway, so I said what the hell and get a set). They were the cheapest "light truck" tire that was in stock. I have to say, I have been pleased with them. They're not really an off road tire in any way, but they've served well, and are at about 50K miles, which is pretty good for $80/tire (I think the tread wear guarantee was for 50K which is about right). So if you are not looking for a more dedicated off-road tire, and want something that is cheap and last a long time, I can recommend those. With the Monty being retired to 3rd car duty, which is more wheelin' and campin' I'll be happy to get a more aggressive tire for my current uses.
tatanka48
hey pard, i might suggest a trip to Discount Tire
i see several within shouting distance
you might ask one of the guys at the desk about what they have that would meet your plans/dreams
almost as if not more important when considering dropping a chunk of change on tires is ¿ WHO WILL STAND BEHIND ? whatever i buy
same goes for batteries
there are often times some really good potential solutions out there that folks in other areas don't have a clue about
and i have personally had experience with DT's guarantee program with very good/economical results not to mention the tires i got from them jumped thru every hoop i put in front of them
just a suggestion
T
dpspc9
Running 285/75R16 e load KO2 with OME HD on both of my Gen3s. They're stiff, but sturdy. I'm amazed by the road performance, quiet and balanced.
coffeegoat
I run Toyo Open Country AT IIs - C Rating = and have been really pleased with them. If I were to do it all over again I would pay closer attention to snow flake ratings. Some of the common choices, KO2's for example, have the fancy severe snow service rating which means they're acceptable with 4 wheel drive to meet "Chain up" requirements in Colorado - which is nice (the Open Country's don't). The other thing to really pay attention to is noise, the Gen III is very noise sensitive, so check around carefully if you're straying from the standard choices (note Plh's comments). Some of these tires have been re-engineering relatively recently (for example the KO2s) but others are getting a bit old.
  • Like
Reactions: plh
surfrig
Surfrig
265/75/16 Falken Wildpeak AT3 (32.2") OME and Bilstein 4600
Great combo, no complaints, has the snowflake tattoo.
DQblues
