tongue extention on M416
Mayne
I'm contemplating lengthening the tongue on my M416.
Any advice on how far out I should consider?
Mayne
I extended the tongue on my M101 about 42" from the front tub - plus the added LockNRoll hitch and receiver gave it another 10-12" - this really helped in backing up and over all maneuverability
It also gave me another place to bolt on a small box
Great, I will look into that! Did you replace the entire tongue this way or did you do some sort of graft?
Mayne
I removed the complete Pintle which left me the two angle metal which came to a point I was able to weld in a piece of 1/4" steel down from the tub - then slip in between the angle steel the piece of square stock that also became the receiver for the LocknRoll - I then added a pieces of 3/16"" steel on the top of the union at the end point. there I made a jack mount, safety chains, and hitch connection.
Photo of the hitch
Some photos in this thread
Thanks, I really like the lid idea too, althought the 416 is a slight bit different in construction. I'll take a closer look at the tonue photo when I get home later.
Mayne
mbobhat
