Tool requirements for FG140 / Canter 4x4 driveshaft
dhackney
Note that to pull the drive shaft on a current generation Fuso FG 140 / Canter 4x4 you need two 17mm combination box end / open end wrenches.
Before you depart on an expedition, make sure you have two 17mm combo wrenches.
You will require both of them if you need to replace a U joint or access anything above the drive shaft.
ThomD said:
Oh man, I hope that isn't the voice of unhappy experience.
Unfortunetly that is what it sounds like.
It probably went like this...
:safari-rig: :confused: :Mechanic: :confused: :Mechanic: :ar15: :camping: :26_16_2: :Mechanic: :smiley_drive:
Not anything catastrophic.
You definately would not want to discover that with a blown U joint on Bolivia's road of death or meeting a Tata on a Himalayan pass or something similar.
I first learned it last July when I pulled the raw water tank out for its first rebuild, but I kept forgetting to post it.
I was reminded last week when I pulled it out down here in Chile for its second major rebuild.
And, I should mention that I am talking about the rear axle drive shaft.
I have not checked the front axle drive shaft to see what size wrench it requires or if you can get a socket down onto the nuts.
Deputy Dan
