Toyota Tundra with Bronco Pop-up Camper - Expedition Ready
Viviana
We are looking to sell our 2000 Toyota Tundra (CA plates) and 2004 Palomino Bronco pop top camper combo.
The truck and camper comes as a set, complete with all the mods and our entire camp and travel set up. You can just move in with your bags and take off. It's an awesome setup for wild camping - you have a complete independence and a great comfort at the same time.
The set is available in California. The price for the total package is $10,000 US.
Toyota Tundra with Palomino Bronco B1200 slide in camper:
2000 Toyota Tundra SR5 V8 4x4 Extra Cab - Silver - 230 000 miles
  • 2 Spare keys -1 key hidden
  • Californian registration
  • 4 Speed Automatic transmission with overdrive
  • Heavy duty tow package
  • Bilstein heavy duty shock absorbers
  • Timbren overload rubber springs - rated 6000 lb
  • Reinforced rear suspension
  • Spare tyre - Tyre rating E
  • Aftermarket custom manifold exhaust
  • Rhino Heavy duty Bed liner
  • 3 inch body lift kit
  • Electric windows & mirrors
  • Fog lights
  • Central locking with alarm system
  • Ice cold Air conditioning
  • Pioneer sound system with iPod connectivity
2004 Palomino Bronco B1200 slide in camper:
  • Camper secured to Tundra with Heavy duty brackets, turn buckles & dual 8000 lb ratchet straps for safety factor.
  • Colour exterior - Burgundy (Professionally sprayed)
  • 12 volt Running lights
  • Windows have reflective tint for extreme privacy
  • Security bars fitted to all windows
  • Master lock padlock system fitted to door - spare key
  • Power converter to AC or DC
  • 200 amp safety trip switch
  • 30 Amp mains cable with 15 Amp connector
  • 15 Amp power extension cable
  • 12volt Deep cycle auxiliary battery with intelligent solenoid charging system
  • 18 watt Portable Solar cell battery charger with regulator
  • 800 watt Cobra power inverter internally fitted
  • 12 volt LED lighting
  • Battery LED auxiliary lighting
  • 3 speed extraction/ blow Ceiling fan
  • 3 way Domestica 3 Cu ft fridge/ freezer AC, DC and propane/ LPG
  • 20 lb Gas cylinder in separate compartment
  • Queen size innerspring mattress including complete set of bed linen and pillows
  • 17 Gal internal water tank with internal water pump
  • Mains water inlet
  • Pre tank water filter and hose
  • Gas hot water heater
  • Hot and cold external utility shower
  • 3 burner stove top
  • Sink with tap mixer - drains externally
  • Gas heater with electric fan
  • External steps into camper - connects to tow hitc
  • Internal storage includes cupboards, drawers and under bed compartment
  • Collapsible dining table converts to 2nd bed or 2 person couch
  • Interior in excellent condition
  • Linoleum floor covered with all weather carpet
  • 5 Gal steel fuel can in padlocked bracket
  • 5 Gal plastic fuel container - auxiliary only
Extra items included:
  • 2 Coleman extra size camping chairs
  • Rio Adventure aluminium camping table
  • 25 litre Coleman cooler box
  • Wheel changing equipment including tyre plugging kits, 5000 lb hydraulic jack and mechanical jacks, wheel brace and 12 volt air compressor
  • Assorted engine water hoses, air filters and spare parts
  • Assorted light globes for all lighting lenses
  • Tarpaulin awning
  • Ropes and tent pegs
  • Spade, tomahawk axe and small wood saw
  • All kitchen pots, pans and utensils including cutlery
  • External step mat
  • Gas stove toaster
  • Professional chefs knife - high carbon steel
  • Cast iron camp oven
  • Camp grill
  • Full set of lonely planet and camping guides from Mexico to Argentina
  • Full set of National Geographic Adventure waterproof maps from Mexico to Argentina. - including notes and info from previous travellers
  • Set North and South American power point connectors
  • 5 gallon plastic utility bucket
Tools and accessories:
  • Set of 3 Emergency triangles
  • 2 wheel chocks
  • 10000 lb recovery strap
  • 4000 lb utility straps
  • Socket set - metric Toyota
  • Spanner set - metric Toyota
  • Assorted Set of screw drivers
  • Allen (hex head) keys -metric Toyota
  • Soldering iron with solder
  • Caulking Gun
  • Vice grips small and large
  • Metal saw ( hack saw)
  • Set of Drill bits (AF or Imperial)
  • Electrical & Duct tapes
  • Oils, lubricants and coolant
  • Kerosine and accelerants
There maybe things we have forgotten or missed. If you have any questions please feel free to ask.
Photos of the vehicle and from inside the camper can be found here: https://picasaweb.google.com/115695589845238860061/Troy02
Please do not hesitate to contact us for more photos, we'll be more than happy to send them to you.
Viviana
viv.vanova@gmail.com
Goldenbora
