BirchHill
goat farmer
I Finished installing OME hd springs in front and medium duty in back along with kyb struts and then had a local chain install new 245/75/16 duratracs mounted balanced and front end aligned last week. Upon leaving I immediately had a vibration from around 45 to 55mph in the steering wheel. Took it back and they assured me tires where fine and that these aggressive treads just rode rougher and I just needed to deal with it . I went home and rotated the tires front to back and upon driving it the vibration felt like it had moved to the back of the car. Now convinced of the incompetence of the balancer I took it to another store with a road force machine and had them balanced again. This resulted in no real improvement, after a week of driving it like this and becoming more concerned I might have a bad tire I took it back. They rechecked the balance and said that everything is balancing out fine and within the range of normal and there seemed to be no defect in the tire. So, my question for advice is am I just being over sensitive and just need to accept these tires as rougher? or is something else at fault? Could it be the increase u-joint angles on 200k mile ujoints from the lift? The new springs really jacked it up from the severely sagged originals. Just depressing for the pathfinder to look so awesome yet drive worse then before. Thanks for your time.
Jon.
Jon.
