So I bought an old M100 as a base. It came with a new 3500# dexter axle with 5on4.5” hubs and electric brakes. Brackets for a RTT that had been purchased. And a few other little odds and ends. With a title already. Got it all for under $400. The tub is in great shape as far as dents etc. it does have a small rust hole in the floor and the floor is pretty bent between the supports. The frame however. It has a crack on one side rail under one of the suspension mounts and the tongue was cut off and has been butchered pretty bad. So I’m going to build an new frame from scratch and put the tub onto it along with a new floor. Make the frame extended up front for the spare and a tongue box. It will have an extendable tongue as well. I also plan to build new fenders and extend the area front and rear of the fender to allow the areas to carry water tanks or fuel etc. I plan to run receiver stock front to rear. Then I’m trying to decide weather to build the rest of the frame out of 2x2 .120 wall or with something lighter like .095 wall. Or even going 2x3 .120 wall. The fenders and side platforms will be made using 1.25” .095wall tubing bent with my tube bender and skinned with steel. Anyway. What size frame do you guys with experience recommend I go with. I tend to overbuild things. I’ll be pulling it with a Jeep Tj on 1 ton axles, 37” tires, 5.13 gears, lockers, 4 speed t case etc etc. I plan on going with 33” or 35” tires in a 10.50 width for the trailer. I know that the Tj has a towing limitation that is pretty low. However with my stretched wheelbase, 1 ton axles and brakes along with the electric trailer brakes I think I’ll be ok towing it on and offroad. However I still don’t want it overbuilt and heavy as hell. Hoping once done and fully loaded I’m under 1500#
any help is appreciated.
