Trailer (stalled project) $1200
drgrenthum
Started building this for overlanding many moons ago and life happened and I no longer have that ambition. Posting this here first in hopes someone with ambition can use this as a base for their build as opposed to a landscaper using it for mulch or something.
Original build thread
This is in sarasota florida.
I have maybe 10miles on it. Just a run up to the local park for testing. Tires were new for the build, I see no cracking but have been sitting for awhile.
I wired all the lights over the last few days in order to help it sell, so that's all new. It is a 7pin. I did not run the wires to the brakes but they are capable of electric braking.
Air lines leak down. I designed it so even without air in the bags the wheels don't rub but I will try and get to those over the next week (no promises) but cheap to repair for new owner.
I have never registered this, in Florida anything under 2000lbs is easy to register as a homebuilt. Check if that is the case if you are out of state. I could register it here first if it is a deal breaker but plan to add a few hundred dollars if that is something you need.
Comes with the lock n roll setup in the pictures. New that is a $419 setup.
Dimensions:
Box width 72"
Box Length 91.5"
Overall length 122.25"
Bottom of rear bumper with bags deflated 18"
Bottom of rear bumper with bags 3/4 full 23"
Email is probably quickest way for me to answer questions.
Aaronrobinsonrn@outlook.com
Clemtiger84
