Trailer wheel adapters ?
Gregny
I need to order some wheel adapters for a trailer It has a a 4/4 bolt patern and I need it to be 4/410 with a 3" offset. Any sugestions on where to get them? .
We can have adapters made to your requirements.
4 on 4" what size studs on the hub?
to
4 on 410 is that 410 mm ?
What size stud do you want inserted into the adapter, what thread pitch.
By 3" offset do you mean you want the adapter 3" thick?
e mail Mario at mario@adventuretrailers.com with all the information and he can get a quote for you.
Not to take away from Martyn but needing that much width and knowing enough to guess that the axle you are dealing with is probably only rated 1000-1500lb and going to have very small wheel bearings and spindles. Putting that much extension on the axle is going to increase the risk of bending the spindle or burning up the bearings.
I would concider changing the axle out. It would not be much more then a set of custom spacers if it is a solid axle and you can order it the width you want. It would be much stronger then what you currently have. I am sure Martyn could source an axle for you just as easy as making the spacers.
You might be able to find something suitable local as well. You could probably re drill a trailer drum to the pattern you need.
Thanks for the replies the trailer is a Bosski atv trailer to pull camping gear offroad and it comes with an odd size golf cart tire/wheel combo. I want to be able to interchange the same wheels/tires from the atv to the trailer. The bolt paterns are different and offset is to accommodate the wheel offset .
Bobbyjr
