Howski
This trip would take us up a 12 mile trail Hatfield (Matt), 88RRC (Ben) LR_Max and myself had traveled previously. We had ridden the trail from north-to-south. This is what would be considered the easier route. Today we would be going uphill from south-to-north. Max was having issues with the fuel on his Series IIa Land Rover and would be skipping the trail ride but meeting us later on. We arrived at the southern end of the trail just after 9am and aired down after chatting about the trail for a few minutes.
I typically air down to 13 psi which I've found to be optimal pressure over the years. It's enough to allow the tire to flex and conform to the rocks while keeping the risk of blowing a bead minimal. Land Rover alloys are known to hold a bead very well which allows me to comfortably go this low.
Matt disconnected the front sway bar on his locked Isuzu Trooper too.
We were all a bit surprised at the water level. It was lower than we all had anticipated.
We expected spring rain to have brought higher water levels than our prior trip. Many of the creek and stream crossings were dry or very low and did not present much of a problem.
If these water levels were up, it could add another challenge to the trail.
The trail continued to cross and run next to creeks and streams for several miles.
Then, the climb began.
Over the remainder of the trail, altitude increased over 1,200 feet. This made for steep and rocky terrain.
Matt led the pack in his Trooper.
We all had concerns about the 100 series due to its size. It is significantly wider than either of the three other vehicles. Front and rear selectable lockers helped Kenneth navigate the Land Cruiser up ledges and large rocks.
Ben showed how capable a small tired Range Rover Classic can be.
The 235/85 KM2’s didn’t provide quite enough ground clearance in this section and led to the only recovery needed on the day.
A quick pull from Kenneth’s Land Cruiser and the Classic was back underway.
