Transmission Drain Plug
cch2a
Curious if anyone knows the transmission drain plug size for a 1993 Mitsubishi Montero/Pajero V6? I went to change the fluid and found the drain plug was stripped and held on basically by liquid gasket. Pan still has threads from what I could tell.
CharlieNorth
Probably an M16X1.5, I have not paid much attention to them. They will be a 14, 16 or 18 mm with a 1.5 pitch, pretty standard size.
cch2a
Well no luck. Tried M8 through M16 and none fit. M10 was the closest but wouldn't thread in. No idea what size it could be.
WOODY2
You may try the Fumoto Valve website, they have a large data base of drain sizes? Just say'n.
cch2a
Appreciate the help guys. Never thought something so simple would turn into frustrating hunt for one plug. I went ahead and ordered a new pan and gasket because in reality I probably should have just dropped the pan in the first place to give it a good cleaning given it's a 1993.
jesus m anderson
