TRDparts4U Deal of the day11/02/10
TRDPARTS4U
Galaxy 60 qt cube cooler (GA-CU-60)
• Outside Dimensions 23"L x 17"W x 18.5"H • Inside Dimensions 18"L x 13.5"W x 14"H • Capacity - 60 quarts • Weight - 20 pounds • Colors - Granite • Approximate ice retention time - up to 10 days • Made of the super durable polyethylene plastic. • Galaxy Coolers have premium pressure injected closed cell foam for insulation. Giving them the longest ice retention of any cooler on the market! • Stainless Steel compression draw latches-The toughest and tightest around! • Marine grade stainless steel hinges that will never break. • Air and water tight neoprene gasket around the lid! Keeping the cold in and the heat out. • The Inner and Outer Shells are non-staining and non odor absorbing material. • Heavy-Duty polyethylene bottom skids so you can drag them forever. • Rope handles that make them easy to carry • Re-enforced lid stops, keeping the lid from ever coming off. • One piece 1 inch drain, fast draining and nothing to break.
$180.00 shipped in the lower 48 states.
4 available.
Please call to order 866 233 4305
AxeAngel
It's a cooler, not a fridge/freezer unfortunately. At that price, they would have been sold out within seconds.
-Sam
