Icewalker
Just came across this idea today - looks like a pretty elegant solution.
http://www.trip-net.co.uk/index.html
Jeff
Jeff
Robthebrit said:Their pressurized water tank is an awesome idea, I thought this system would work and had plans for an experiment using a cylinder from a jet toilet (of all things). Water under pressure with no pump is one less part to fail, but there are some serious downsides, mainly the cylinders are very complicated and the output pressure is the same as the fill/input pressure and there is a minimum and maximum working pressure. You have to fill it under pressure from a city supply, this excludes lakes and streams and many third world water sources. Of course you could have a pump but that puts you back at square one.
Rob
Out put pressure could be regulated with a simple drip irrigation pressure regulator.Robthebrit said:Their pressurized water tank is an awesome idea, I thought this system would work and had plans for an experiment using a cylinder from a jet toilet (of all things). Water under pressure with no pump is one less part to fail, but there are some serious downsides, mainly the cylinders are very complicated and the output pressure is the same as the fill/input pressure and there is a minimum and maximum working pressure. You have to fill it under pressure from a city supply, this excludes lakes and streams and many third world water sources. Of course you could have a pump but that puts you back at square one.
Rob
