Tripplite PowerVerter 3000 Watt
Rovertrader
Supporting Sponsor
I'm interested, and have read the link provided. Here is my question: I am going with a second battery, and an inverter. Is this model capable of d/c incoming and convert to 110( I believe it is)? Then, is it capable of 110 incoming and charging the battery? I invision a second battery in the bed of the truck/Flippac wired to the primary with a disconnect solenoid. Then also have a plug-in on the outside of the truck directly to the invertor for shore power. Am I on the right track with this setup you have for sale? Thanks for your patience- I hate electrical!! Cheers, Dale
LukeD
Dale, yes this converts 12v to 110, and yes this will charge your batteries when plugged into shore power as it has the battery charger built just for this (from the link - When hardwire AC input is energized, commercial power passes through to connected equipment and the battery set is recharged via 3 stage, selectable 35/140 amp charging system)
Cheers,
Luke
Rovertrader
Supporting Sponsor
Thanks Luke- that is what I got out of the litterature, but needed to confirm. Very interested- pm me with a super deal and it will be sold :victory: Cheers
Dale
Clemtiger84
