GuestArtist
Greetings EP members, I'm an enthusiastic reader of this forum and mechanically-inclined neophyte with RV building.
I recently acquired sandwich panels which are cut-outs used in the manufacture of garage doors. Each panel is either 20"W or 22"W, with 80"L and having a thickness of 1.75". The distributor of these panels markets them as insulated wall coverings for shop and farm use, but they seem like a great material for an RV. Given the very inexpensive price being charged, the purchase of these panels was a no-brainer given their almost perfect dimensions for the build of a slide-in truck camper I've been pondering.
Though I figured it might be a challenge to join the narrow panels into larger watertight assemblies, my long road trip to the distributor's location gave me plenty of time to appreciate how much more effort I'd have to expend attempting to wrap my own panels from XPS which likely wouldn't result in nearly as good quality as these.
I discovered these panels are composed of a ~2 lb. PU insulation core and faced on both sides with a white gel-finish FRP sheet, having an estimated weight of perhaps 20-23 lbs.
The proposed project can be described as a truck camper with no cabover, having overall dimensions of 76"L x 66"W x 66"H with a 40" wide floor. I'm hoping to achieve a sub-400 lb. unloaded weight. While these parameters should easily support mounting in the bed of a mid-sized truck, initially I'm thinking to secure it to a 4x6 trailer.
The construction method I'd utilize is butt-jointed panels supported with angle brackets bonded on the exterior and interior corner joints, with perhaps a series of rivets for facilitating placement of these angles.
For the roof assembly I'd join three 22" panels along the long edges, aligned and reinforced with shallow splines inserted and epoxied behind each face perhaps 2" on either side of the joined edges. Further reinforcement of the entire assembly might come from tubing embedded inside the perimeter. Being a horizontal surface exposed to constant elements, it would probably be wise to glue an additional FRP layer to the exterior face to seal the joints, instead of relying on a fileted epoxy joint or sealing strip as I may attempt to incorporate on the vertical surfaces.
I'm hoping that the experienced amongst you can (in)validate my proposed approach and make comments that are not just limited to...
-- where/how to install lifting points (alternatively could the unit be somehow winched/dragged/rolled onto a truck bed instead of lifting)
-- necessity for reinforcing of panels/assemblies with embedded tubing or other
-- suppliers of angle/corner hardware (eg where to find FRP angle less than 1/4" thick) and compatible adhesives that are available in the USA
-- method for reducing the height of a standard RV door assembly for adaption here
Construction will be taking place in a residential-sized garage bay which is partially heated and can be supplemented with temporary additional heat.
Thanks to all for your prior contributions and I look forward to the comments.
