Tucson AZ- Alu Cab drawers $1500
DDT
For Sale Alu Cab sliding drawers.
Fits shortbed Toyota Tacoma
AluSD1230- Single drawer 48” long x 20” wide x 11’ high Well made and light. See at https://www.alu-cab.com/products/ Accessories- Drawer System
Purchased from ok4wd at $895 x 2 = $1996
Installed and immediately removed, never used. Like new except I cannot find the drawer keys. Will sell for $1,500 cash.
All – Aluminum Drawers
Each systems starts with a laser cut aluminum housing which features cut outs to minimize weight in non-critical areas while still retaining maximum strength. The drawer bodies are too laser cut and bent for precision, tig welded and lined in marine carpet. Each drawer also features a stainless steel latch with built in lock to keep items secure and dual spring pins that allow the drawer to be removed without tools.
Sealed Roller Bearings
Each Alu-Cab drawer system features 24 sealed roller bearings that will not only work well when new, but will survive the rigors of off-road travel for years to come. Each bearing is also individually serviceable if ever requiring attention so your system never needs to be retired.
Tacoma Top Plate
These Toyota Tacoma bed drawers include a CNC machined top plate from 12mm marine Grade Baltic Birch coated in a non-slip polyuria coating. This not only gives the system a clean appearance, but allows for additional lockable storage beneath the surface around the drawers. This area can also be used to mount an universal 50l water tank. Additionally the 12mm top plate is the perfect blank canvas to mount your fridge slide or any accessories you choose.
Weight Savings
Not only is aluminum construction strong, but it is much lighter than wood or steel. Alu-Cab Toyota Tundra bed drawers are nearly half the weight of wood and steel systems on the market, allowing you to carry gear for the total weight of other’s systems empty.
SANelson
