Tuffy TJ/LJ Conceal Carry Security Drawer
RocKrawler
Supporting Sponsor
This high security 16 gauge steel security drawer mounts under the drivers side seat in a Jeep TJ & LJ (No Flip Seat). The formfitting
design of the Tuffy lockbox has over 336 cubic inches of lockable storage. It's secured contents are easily accessed by
maneuvering the drawer open and closed on the smooth ball bearing slides using the convenient pull lever.
Featuring Tuffy's Pry-Guard Locking System with a 10 tumbler double bitted security lock with built in weather seals. The design
incorporates a heavy duty fully extending slide system, weather seal & welded construction. A formed rib in the enclosure
additionally strengthens the locking system.
Mounts inconspicuously under the drivers side seat in a Jeep TJ (No Flip Seat) & LJ (No Flip Seat) out of apparent site of would be
thieves. Uses the factory hardware without drilling. The drawer must remain locked while operating the vehicle. Manufactured by
Tuffy in the USA.
FEATURES:
- Over 336 Cubic inches of lockable storage space
- Exclusive 10 tumbler double bitted lock with built in weather seals
- Pry-Guard locking system featuring 1/8" thick welded steel components
- Pull lever for easily opening and closing the drawer
- Formed rib in the enclosure additionally strengthens locking system
- Stealthy design is hidden under the seat from prying eyes
- Welded 16 Gauge steel construction
- Easy install, no drilling
- Durable texture powder coat
- Heavy duty smooth rolling ball bearing slides
- Weather & dust seal
Interior Dimensions : 16 13/16” L, 7” W, 2 7/8” H (2 1/16" Clearance under latch bracket)
Mounting: No Drilling required. Fastens with original OEM hardware and included fasteners.
FITS: Jeep Wrangler TJ 97-06 & LJ (Fits vehicles where the drivers seat does not flip all the way up. These vehicles DO NOT HAVE the CAFS code on the Jeep build sheet = "Easy Access Driver Tip & Slide Seat" or "Easy Access Driver Seat")
Introductory priced at only $89.99
irish_11
If I could find something like that for my Tacoma I would be sold. I have to figure out a way to clear the hump in the floor first though.
Goldenbora
