Uh oh
jeeper92
Top was left off of my tj and now my turn signals wont work...Is there a checklist that anyone has that could be causing the problem? Ive already checked the fuse and they are good.
Thanks guys!!
alosix
TJs have a terribly picky turn signal switch, especially the older ones.
Check to see if your brake lights and 4 ways work as well.
Jason
chicagojeeper
I had the same problem, but mine turned out to be a hairline crack on the body-side of the left tail light (prob cracked at the car wash). Water got in , rusted, and eventually shorted everything. $21 for a new universal tail light solved it. You can unscrew the four cover screws to check out your internals.
fireofficer001
