Under body power distribution
Stitebunny
I’m looking to add a power distribution block/fuse panel under my van.
Supplied by the under body leisure battery bank.
It will get mounted out of direct water/mud, unlikely to see deep water crossings etc.
Any recommendations for a “waterproof” unit?
I live in the PNW and it can stay pretty damp under the vehicles. Maybe a 6-8 circuit system would be enough.
Thinking maybe one of the Bluesea panels would be a good option?
llamalander
The Blue Sea Safety-Hub 150 is a solid small panel that can carry significant loads--it's ignition protected, but in no way waterproof.
I would be surprised to see that anyone makes a waterproof panel, You may do better mounting a pelican or knock-off waterproof box and using strain relief connectors to keep the wire-entry points sealed.
Alternately, they do make waterproof breakers, you could wire up a bank of those and maybe velcro a cover over them to keep them cleanish.
Under a vehicle is a pretty dirty place, with plenty of small objects traveling fairly quickly bouncing around--personally, I wouldn't subject something as important as my electrical system to unnecessary abuse...
Alloy
Road salt/dirt is a magnet for condensation. I've seen voltage leak 3" through the salt/dirt mix.
Coat the connections with Tef-Gel or NOALOX as well as the cable seals/ grommets/orings.
Fuses aren't waterproof. I've had them turn green inside.
dstefan
Bluesea does make sealed switch panels designed to be out in salt spay. They have IP 67 or 68 versions. Look at their website. There are multiple ones.
SANelson
